Machine works 100%, boards look good, cabinet looks good, but the
playfield is insanely dirty, balls are all rusted, and screws look
corroded. What do you think? $2500 ballpark?
I agree with pin-tastic. It's a little high. You may be able to barter, but don't hold your breath. For me, it usually boils down to 1 - How much do I want it, 2 - How likely am I to find another better deal, 3 - Am I going to keep it (If I am, I don't mind putting more work into it).
G
Thanks for the input, I called back and said I can only offer $2000, if she sells it for more then it wasn't meant to be. I really do want it, but I am likely to find one for around the same price in better condition ($2500), and yes I would keep it. Definitely a pin I really want, and it was nice that there were no errors, and everything was working, including the guns above the slings. Did I make the right choice? What if all I needed to do was clean it up and replace the corroded screws? Am I losing out? I have a headache.....
I hope it wasn't a diamond in the rough and I miss out on it.
That's the thing.. should I just get it for $2500 and not lose out on the machine to someone else, clean it up and now I have a machine that truly is worth what I bought it for? I like to work on them as much as play them, just not sure if I want to open another can of worms and find something truly wrong. I went through diagnostics, all solenoids worked, switches worked, no errors, guns worked great, it's not so much the dirt as the corrosion that's bothering me. Cabinet was a 9, backglass was a 9.5, playfield other than dirt was a solid 9 at least, I saw no wear around the outholes. I'm really stumped on what to do..................
Well therein lies the rub BriGuy...
Do you take the time to get the rust off of everything metal? (Time VS money?)
Or do you wait for a machine that is a little more inland that was dry but now has a little more PF wear and who knows what else? Oh and it is now $3000 because it is a month later...
(see current price hike for BSD!!! "thanks" Pinside...
Remember you just rolled three 9's on condition...
I have seen much worse, for much more!
If it makes you feel better, I have overpaid for more than one pin. If the cabinet and boards look good and the playfield can be cleaned up. It might be worth a counter offer at $2250.
The price sounds a little high to me as well. Does it have any mods or add-ons? Keep in mind, by the time you start adding some necessary things like ramp protectors (above and below), Pinbits trough protector, NZ Cliffy, etc ... the game will end up costing you more. Also, if any of the ramps are cracked, that's an additional expense.
Hah NB, you said "screws and balls"
Quoted from BriGuy5:
Give it some time (today) and if they don't ring you back, if you REALLY want it, give a different FINAL offer. $2200? $2250? Just trying to encourage you BG!
I guess it's how bad you want something more or less then the next guy?
and what is $500 anyway?
you can blow almost that amount taking the wife and kids to Yankee Stadium?
Sure if you can wait a year or two you might nail a Sttng cheap - then again maybe not?
$2,500 is too high. It's one thing if it was just dirty, but machines like that usually need $200-$300 in parts not to mention the hours of time. $2,500 - $2,700 will buy you a nice STTNG all day long, they made plenty of them. The rust could be a huge problem, did you look under than playfield to see if anything down there was rusty?
Rust is evil - make sure the bottom of the playfield is clean...if the screws etc are lightly rusted its one thing on the top - can be replaced but if its bad, springs rusty on coils, wires, etc I would stay away, its had a very damp home, and I just got done with a game like this... its not fun, wait for a decent dirty one but not rust.
Thanks all for the advice. I decided to pass and the machine was then sold for the asking price to someone else. Guess it wasn't meant to be, but I'm sure one day in the future our paths will cross again, and hopefully an even nicer machine will emerge. Pinball sad face, time to go finish TZ and play the hell out of it.
Don't feel too bad about it. I've seen pretty good ones go at that price before. They don't always head north of $2,500, but you will need to wait a bit to get a good one in that range.
That's the right attitude to have. You will have a chance at another when the time is right just keep an eye out and your pin will find you.
BriGuy - I bought mine for $2K, and talked him down from $2200 because of a reset problem when you hit both the flippers.
Turned the game on, - time & date not set - (bongbongbongbongbong) Check the boards, some battery acid but not too bad, and one switch error. I was pretty new at this and told him it would be $200 for a new MPU board, and the game was pretty clean. I should have docked him $100 I gave my friend for helping me get it out of his basement and use his truck.
But some Deoxit on the terminals, and picking at it with a toothpick for an hour, new batteries, and she reset once in a year. I've since moved the batteries off the board. But at first I had no idea what I was doing. lol
At the time I bought the game replacing a lot of corroded parts would have taken me forever. Otherwise we've been playing it. Occasionally malfunction-mutliball, so cleaning the opto's is needed. So the cost is justified by playing. You'll find a better deal.
Picard, "Steady as she goes."
