Hello,
First I am a French guy (sorry for my english) and today I solicit the international community.
To date, after more than 3 months of investigations, waiting for deliveries, revisions, modifications,... Well, my Gottlieb Tag-Team Pinball (SYS80B) still doesn't work!
I expose here the current symptoms (which seem to be stable and do not evolve any more):
- When turning on the pinball machine, the T.A.G target set rises twice but not the T.E.A.M target set
- In solenoids test mode, the tests of SOL5, SOL6 and SOL7 raise ALL the T.A.G target set (and only this one)
=> Note that SOL5 = T.A.G ; that SOL6 = T.E.A.M and that SOL7 = is not supposed to be used !
To see this, I suggest to watch this Youtube video :
- At the start of a game...
- the T.A.G target set rises twice but not the T.E.A.M target set
- the pinball machine acts as if (at least sonically) it were starting two games in a row (the game start sound sequence is heard twice)
- lowering targets does not produce any sound
- the sounds are (sometimes) not adapted to the action
To see this, I suggest to check this Youtube video :
Obviously, and as is, the pinball machine is not functional. I've been looking deeper for more than 3 months now (problems discovered on March 19, 2022; globally following the dismantling of the cards from the backbox to take pictures of them) but I can't find the cause.
So I did some things on the pinball machine. I expose here all that has been undertaken:
- Replacement of all the fuses of the pinball machine
- Complete overhaul and "refurbishment" of all the backbox cards (by a pro)
- Purchase of a new power supply card (with a small 5V display)
- Measured the 5V output of the power card: 5,08V
- Measurement of the 5V at the CPU : 5,00V
- Measurement of the 5V at the level of the driver: 4.94V
- Change of all the pins of all the connectors of the backbox (except the bifurcated; black connectors for the moment cause I don't have them)
- Test without black connector (A3-J3) of the driver
- Test with another CPU <=> Driver connector (A3-J1 -- A1-J4)
- Complete overhaul of the backplane's mass holders / "nipple cards"
- Change of all the ground connectors' pins but also those around
- Disassembly of the TAG target set, checked coil, etc.
- Check (but not replace) the connectors of the TAG and TEAM target blocks
- Checking the fuse holder of the bottom plate. Cleaning the supports.
- Measurements at the terminals of the large capacitor of the bottom plate (12.86 / 12.93 depending on the mode because in "attract mode" the flipper alternates between yellow illumination / red illumination equivalent to the multi-ball mode in game).
Rem: I didn't change this big capacitor (I only have to change this one, I think) but this one is not the original one.
- I checked the small plates with the diodes. All the diodes seem to be good. They block well in one direction and give a value (multimeter in diode mode) in the other. However, the values are not identical between the diodes (I do not know if this has an impact)?
At this stage, I really ask for help, tracks, suggestions or any element which can help me because there, I really do not know what to do...
"PLEAAAAAASE HEEEEEELP" (to quote Leeloo, in the 5th element)
