Hi, in a pickle with my Iron Man VE (Sam 520-5352-00 CPU/SND & 520-5249-00 Power) not booting.
Game was working fine last night until whatever caused the blow out/problem.
Have removed solenoids high/low power, GI, Display, which is colourdmd, sound connections since.
After removing above and turning on:
Turn machine on, GI fires briefly and turns off, switching power board Fuses F1-F4 inclusive to OFF. The fuses F1-F4 test fine with a multimeter out of the machine.
On the power board, F1-F4 leds are out despite being good.
All other Fuses are led red on and test good.
All voltage led's in a vertical line are all green.
Led around C75/L18 is orange.
Am not sure what else should be lit?
On the CPU/SOUND board, the power led is lit and Led 3 is flashing.
I fear the worst, any clues other than my power or my cpu/Rom is bad?
I'm in the UK and hear all kinds of problems about getting it repaired or another board.
- Cheers Martyn.
PS Machine was modded by previous owner, had translite flasher upgrade, colour dmd, replacement bumpers, Led-Ocd. I've removed these mods whilst under investigation.
#IM
