(Topic ID: 88610)
Iron Man Club: Adrenaline Junkies Welcome!
By RobT
7 years ago
  • 4,556 posts
  • 389 Pinsiders participating
  • Latest reply 5 hours ago by newpinbin
  • Topic is favorited by 132 Pinsiders
There are 4556 posts in this topic. You are on page 91 of 92.
#4501 22 days ago
hi guys
SW just gone, i'm feeling that my next pin will be IM... long time on my wishlist, never conclude, may be this is the right time
talking about the VE, does owners of the last 2019 run are thinking that "big" magnets are a prob ?
i know already that most didnt like the MARK3 blue insert
#4502 22 days ago
Quoted from newpinbin:
Did it work for you?
Nope. I downloaded to the usb as instructed but it doesnt load code. It makes a noise that it recognizes the usb but no update initiated.
#4503 22 days ago
Quoted from RipleYYY:
hi guys
I like the magnets and mark 3 blue insert is fine. /shrug
#4504 22 days ago
FYI the update wipes your configuration and high scores. Probably stated before but I missed it.
#4505 22 days ago
Quoted from glpinball:
I forget but does the mark 3 blue insert have some significance in the gameplay?
#4506 22 days ago
Quoted from libtech:
Code with updated and added callouts : this is the working d/l link https://drive.google.com/file/d/196TiE_Rm5jkiWq5Bq26PJa6-naZerJOb/view?usp=sharing
libtech thank you for making the file available. Just wanting to confirm the file size is 28.3MB? Copy to the root directory of a USB stick and then update in the normal way?
#4507 22 days ago
Quoted from pinballjj:
yes, Lyman added something, i think its extra ball available at the left ramp !?
need to read the update list...
#4508 22 days ago
Quoted from Alaskanzen:
I just installed it in mine and works fine.
#4509 21 days ago
Arc reactor bonus, must be collected at the center shot.
#4510 20 days ago
Quoted from Lostcause:
Does it change any of the original code or does it just add to it?
#4511 17 days ago
I put my Iron Man Up for Sale.. It's on Pinside marketplace..
#4512 17 days ago
Yes sadly I've listed my beauty as well here in Australia...
20210830_151610 (resized).jpg20210830_151628 (resized).jpg20210830_151706 (resized).jpg20210830_153735 (resized).jpg
#4513 17 days ago
i've gone to check a IM VE (last run) i had interest in, but than i noticed main cab decals were bulling (the 3 sides !) as it happends on lots of KISS...
never seen that before on IM, and seems nobody reported this until now !?
#4514 17 days ago
"bulling", I'm not sure what that word is ment to be, could you describe it in a different way?
Did you mean bulging/protruding/swelling or stretched decals?
Quoted from Jakusu:
Yes sadly I've listed my beauty as well here in Australia...[quoted image][quoted image][quoted image][quoted image]
God damn those whips! Not willing to separate?
#4516 17 days ago
ahh. crinkled or creased perhaps.
Seems to happen when the bolt twists when it is tightened and there isn't a cutout around them.
This other thread talks about it in the context of near the legs so should be similar for the bolts too : https://pinside.com/pinball/forum/topic/wrinkling-decals-suggestions-to-repair
I had a tz with similar issues and all I did was remove the bolt, Gentle heat and smoothed it out. Pressed flat again and reinstalled bolts and was careful to not twist them again. IM has those gold reflective decals so im not 100% sure what any heat would do to them. You could try without any heat first and see if that helps.
#4517 17 days ago
Quoted from koops:
... but than i didnt bought the pin, for this, and also the right ramp entry being (a little) broken
meanwhile a friend of mine should buy it anyway, will see all this than
#4518 16 days ago
It’s been mentioned in the past, during the initial VE run. I’m not sure if they changed anything on the latest run, but I’ve seen the wrinkling effect happen on all original VE’s. I’m a little OCD, but I guess not as bad as others, as I don’t even notice it anymore and the wrinkling is not worsening over time either.
#4519 15 days ago
Quoted from evileye:
I have the same issue on mine. Mine is later run. I tried a little heat and smooth it with a credit card and it only helped a little. Stern sent me a replacement front cab decal. Still waiting on the side cab decals. I'm likely going to replace my armor with the side rail that covers the buttons....this will solve the issue on the sides. The front issue is around the coin door.
#4520 15 days ago
Quoted from insight75:
the one i've seen had this (as exposed above) mainly where screws did push/turn & enter the wood, but also around the flippers buttons & under the metal rails
#4521 13 days ago
Quoted from PinRob:
Added brass key lock, ordered a 7/8” lock, Amazon sent 9/16” but it worked fine with the flat bar catch piece as opposed to the 7/8” lock’s bended catch.
Thank you for sharing this. The silver lock always bothered me with everything around it being gold/brass. I couldn’t Powdercoat it so I didn’t think I had any other option.
This new lock completes the game. A little detail that no one will notice but me, but my OCD is finally happy.
Below is the before and after…
D85EEE23-02DE-400E-A074-F657CA431E91 (resized).jpegE9ED6FAA-3027-4708-A911-A7CBDE6AD18C (resized).jpeg3C110D8E-877A-4A89-B83E-16F1D0B24AFA (resized).jpeg9899DE19-FB7A-42FC-BFB6-8A938D37AEB3 (resized).jpeg
#4522 11 days ago
Below is the before and after…[quoted image][quoted image][quoted image][quoted image]
Glad someone else shares my attention to details! The silver lock always bugged me after I spent a pretty penny to have all the screws and bolts brass plated.
#4523 11 days ago
Quoted from PinRob:
I hear that! I even replaced the silver shooter spring with a brass one. The lock was literally the last piece left that wasn’t red/brass.
#4524 7 days ago
I know it’s a long shot, but anyone have the stainless stark industries topper they wanna get rid of?
#4525 6 days ago
Is there a video out there somewhere that shows all of these additions? I searched the “Tube of You’s” and didn’t find anything. I’m still on the fence about buying one of these, and I feel like seeing the version with the updated songs and callouts might be just the little push that I need. Cheers!
#4526 2 days ago
a new friend is in the garage...
but than will not last long as it not "mine", but just friendly dropped for a moment (who knows what this last word could means !? lol)
#4527 1 day ago
When you spell monger the center shot needs to flash to indicate you can raise the monger. My flasher is not flashing. It just turns on solid and stays lit. When I run a diagnostics I am able to manually make the flasher flash each time. Does anyone know why during gameplay the flasher stays solid once it is activated? I have changed the flasher bulb 3 times already and it has not helped.
#4528 1 day ago
I do not believe that is the case. Monger can be set to "easy" where any orbit will bring him up once qualified or "hard" where only the center orbit will bring him up. I am not aware of anything in the code that is meant to flash those inserts once he is qualified. I have my game set up with "hard" Monger so I have more control of when he enters the playfield.
#4529 1 day ago
Quoted from Reaper802:
I have mine on hard as well which requires the center monger shot to make him rise. That center shot has two lights one being a flasher bulb. Once you spell monger this flasher will continuously flash to indicate that you need to make the center shot to rise the monger. For an unknown reason my flasher will just stay solid and not flash at that time.
#4530 1 day ago
I like this. I'm going to make this change.
#4531 1 day ago
Also change your whiplash flashers (there are 2 of them) to the blue ones. Makes a huge difference.
#4532 1 day ago
For what it's worth, my game has never done that. Can anyone else post video of this flasher effect happening?
#4533 1 day ago
Anyway you can capture that?
#4534 1 day ago
at 10:12 you will see the center shot flasher on
#4535 1 day ago
Check in diagnostics (flashers) to see if your flasher works. It may be burnt out.
#4536 1 day ago
Photo does not do this justice. But these are the blue flashers installed on whiplash. I took the pic in test mode so all the playfield lights remained on. During gameplay all white lights turn off when the target is struck leaving the blue flashers on. Makes a huge difference compared to the standard white flashers.
#4537 1 day ago
Anyone have the wiring schematics diagram for the flashers they could post on here?
#4538 1 day ago
Sick, need to add that to my Comet order I’m putting together.
These will work, right?
https://www.cometpinball.com/products/8smd-flashers
#4539 1 day ago
Those are the exact ones I used. You need the bayonet style for the flashers. I also changed the two flashers under the Iron Monger to blue as well.
#4540 1 day ago
These are the colors I chose for the display lighting. In my opinion adding tasteful color to this basically white light only playfield made an enormous difference is the satisfaction I have for this machine. Adding the blue flashers made it that much better.
20210916_094028 (resized).jpg20210916_094036 (resized).jpg20210916_094048 (resized).jpg
#4541 1 day ago
Appreciate you confirming and the pics too. Thanks, it does look great!
#4542 1 day ago
12 news posts in few houres !!!???
was really thinking that a new code was just dropped...
#4543 1 day ago
Yes, when Jericho is ready not when Monger is ready. Does your flasher fire when you qualify Jericho?
#4544 1 day ago
Mine is messed up. It is supposed to flash when the Monger is ready.
#4545 1 day ago
Watch 7:32 monger light flashes letting the player know to shoot the middle to raise the IM.
#4546 1 day ago
For those of you not seeing this on your machine the flasher is either burnt out or you don't have the monger set on hard. On the hard setting the only way to raise him is via the middle monger shot.
#4547 1 day ago
Looks like you have the VE made in 2020. I heard they made around 50 of these to send to Europe. I think the other 50 made in 2020 ended up in the USA. Has anyone else heard this?
#4548 1 day ago
yep, that's the last run
and you may be right about the numbers, i think this has been already talked here
#4549 1 day ago
Glad I got mine from the 2020 run. IM has to be one of the most enjoyable machines I have ever played.
#4550 1 day ago
I have one from the 2020 run. Great for a quick game of pinball.
