.92 code...when the shaker motor activates it causes a slam tilt reset.
Unplugged it plays fine.
We tried a different shaker motor and swapped playfields , both had same effect. Possible code issue?
Quoted from CafeOne:.92 code...when the shaker motor activates it causes a slam tilt reset.
Possibly a code issue; are you using the red tremor shaker?
I don't honestly know if it is a red tremor or not. It's whatever little shop of games installs....I've used the same one in GB premium, AS pro, SWLE, GOTG pro with no issues...
I'm banking on a code issue, but wanted to see if anyone else who has it is having the issue.
Quoted from CafeOne:I don't honestly know if it is a red tremor or not. It's whatever little shop of games installs....I've used the same one in GB premium, AS pro, SWLE, GOTG pro with no issues...
Is the plastic cover on the shaker red, white, or clear?
Quoted from robotronjohn:What about the slam tilt switch, is it out of adjustment?
Aren't they "optional" (not included) on newer Sterns? I seem to recall there's a flag on the coin door with a "this is where slam tilt would go if we gave it to you."
After swapping a node board with GOTG, same result.
Stern is sending out a capcitor that attaches to the node board that should eliminate the problem .
I am very surprised that they did not come with the caps...... this was an issue that they just sent revisions out on.
Curious as to the results here, looking to get a shaker for my iron maiden. Is everything working with latest code? Did you need extra parts from Stern?
This page was printed from https://pinside.com/pinball/forum/topic/iron-maiden-shaker-causing-slam-tilt and we tried optimising it for printing. Some page elements may have been deliberately hidden.
