Not sure what's going on but can anyone help?
My top RHS flipper makes this thud sound while playing. more so than the other flippers??
Hopefully this video explains and shows what I mean. Just started happening!
Did you try pushing your pf to the left once its down? I noticed that after lifting the pf on mine I would get a noise from the top right flipper when I dropped it back down. If I nudged pf to the left when it was down to get it away from the right side of the cab, the noise seemed to go away.
Quoted from Flex_in_Aus:Did you try pushing your pf to the left once its down? I noticed that after lifting the pf on mine I would get a noise from the top right flipper when I dropped it back down. If I nudged pf to the left when it was down to get it away from the right side of the cab, the noise seemed to go away.
Hmm, ok...will try tonight.
Do you think it might be hitting something on the right side??
I’m having this same issue on mine, the metal flipper plunger stop bracket is vibrating the right metal side rail every time the right flipper is struck and making that thud sound. That’s why when you lift playfield it doesn’t make that sound anymore. Was thinking about putting some dynamat in between the side rail.
Quoted from FtWorthPinsider:I’m having this same issue on mine, the metal flipper plunger stop bracket is vibrating the right metal side rail every time the right flipper is struck and making that thud sound. That’s why when you lift playfield it doesn’t make that sound anymore. Was thinking about putting some dynamat in between the side rail.
Chuck up a photo if you can of what you mean please. I noticed that some screws were needing tightening but didn't want to pull apart the mech.....well...cause I'm lazy....haha
See where I have the felt pads (ghetto rigged I know) on the the metal stop bracket on the upper right flipper, it’s touching the right side rail and making the thud sound you hear.
Wow! That's really close! This "mod" hehe, has that reduced the noise? I'm guessing yes.
Presume this will have no detrimental effect to the mech if left alone?
The felt pads have helped a little, but still making that thud sound. It’s pretty annoying when you’re playing so need some other sound deading material like Dynamat (haven’t tried it yet). Let me know if you figure something else out?
I think I'm just going to ask FalconPunch to come over and help...seems he won't help in here...hahaha!!
thud is the upper RH flipper mech/coil stop (one piece assembly so coil stop is not removable separate from base) is touching the playfield rail, cause could be seasonal change in playfield bow or flipper assembly coil stop fatigue from use, solutions can be: filing away the coil stop metal that is touching the rail, try re-positioning the flipper assembly so the stop does not touch the rail or filing a notch into the rail where the stop touches it
