I apologize that I jumped the gun there on the coils. I can confirm all coils work. Had run a test and thought it was running through each coil and firing but it was not. I can confirm they work.
Everything works except the bottom 2/3 inserts. These are all the lights from node 8b, 8c, 8d, 8e. I checked every connection on node 8. Solid as a rock. Checked the serial cables on all 4 sub-nodes. All good. Have to think the node board is bad (at least the part controlling those inserts.) Did I miss anything?
No interlock. Wow. Power switch next to go? "Just plug it in and unplug it when you're done." -Gary
