(Topic ID: 215735)
Iron Maiden Mod Thread
By Lermods
2 years ago
  • 864 posts
  • 171 Pinsiders participating
  • Latest reply 6 months ago by Mahoneyj
  • Topic is favorited by 121 Pinsiders
There have been 496 images uploaded to this topic. (View topic image gallery).
There are 864 posts in this topic. You are on page 12 of 18.
#551 1 year ago
I used the existing led and just flipped it so it faces up underneath the plastic and added a washer to keep it level and used the next size up in length screw
Works like a charm
I have a few people interested so I’ll order more stuff to make a few
#552 1 year ago
Finally got around to lighting his eyes too
#553 1 year ago
Quoted from Hdmike444:
Finally got around to lighting his eyes too[quoted image]
Very cool. Couldn't have been easy working with such a small area. Care to share how you did it?
#554 1 year ago
Quoted from Fytr:
I drilled from front to back aiming towards his neck area with a tiny bit then kept going up one size until a Pico led fit in from the back. The less are about halfway in as they are too bright at the actual eye ball
Wasn’t as bad as you might think
#555 1 year ago
How did you run the wires to the LEDs though?
#556 1 year ago
Quoted from Fytr:
The leds came with about a 6” lead
I glued them running down his back and leg and added length to it and connected it to the pop bumper light so it works with the two that are not flashers
#557 1 year ago
Awesome job. This could be my favorite upgrade. Where did you pick up the leds?
#558 1 year ago
Quoted from bigduke6:
Thx. I used Evans designs, they are a model train led website but have a ton of great leds. I used Pico warm led 6-12v iirc. I bought cool also to try but they were too white.
Working on my spitfire mod now. Hopefully it will be finished over the weekend. Then I need to find a replacement somewhere in time eddie and give him a little upgrade.
#559 1 year ago
Ok, finished my spitfire! Added 3mm leds from lighthouse, and made a wiring harness that ties to the right side flasher.
I'm sure its not as pretty as what lermods makes, but learned some new skills making it. Thanks for everyone's help with making it. And...now I just need to pin down when exactly the right side flasher goes off.....its not that often I guess so I barely get to see my hard work!
#560 1 year ago
Hmmm...looks like the lermods non-interactive plane just has the lights on all the time. Maybe I'll switch them to that eventually if I rarely notice them flashing.
#561 1 year ago
Quoted from Gogdog:
What are you trying to accomplish? You want the wing lights to flash? If you have them tied to a flasher, why are they always on? Our non interactive is hooked to GI so it’s always on? Our interactive is tied to two circuits, underwings always on to light the playfield and wing lights on/off tied to a flasher. Pm me or ask here if you want help. It’s a fun project to take on if someone wants to learn.
#562 1 year ago
Quoted from Lermods:
Sorry for the confusion....I have mine wired (and working) just like your interactive one. I originally said ->
As in....I don't see the flasher "light" very often, which means....I don't get to see the spitfire flashers very often. I'm saying I'm contemplating switching to your non-interactive style just to have them on all the time.
#564 1 year ago
Ideally....I would have the spitfire lights flash when someone hits the right ramp, though I think that gets much more complicated, though someone has made a spitfire mod that does that which is for sale (I just don't like the model spitfire they used).
Now that I'm thinking about it, I also have the mezelmods obelisk dome cover ->
https://mezelmods.com/collections/iron-maiden-legacy/products/iron-maiden-pinball-obelisk-dome-cover?variant=12219491876980
On the Pro model....the light is only a simple flasher and...doesn't go off that often. So...I don't get to see the obelisk lit up that much. I think on the Prem/LE its a RGB that turns on during most of the modes and stays on?
Now I'm thinking of adding a 3 SMD led red strip from comet and putting it in there so its always lit up, and the flasher will still go off of course for a bit of visual feedback.
What might be cooler....is having one of comet's fire LED bulbs always on. -> https://www.cometpinball.com/product-p/fire.htm?1=1&CartID=0
The thing is...I would need to stick in a bulb socket and might not have enough space. Might look really cool though.
Also, anybody know where to get the foam tape that mezelmods and everyone else uses on most of their mods?
#565 1 year ago
Quoted from Gogdog:
I have no idea what other modders use, but I swear by 3M extreme mounting tape. You can get it at Target and home improvement stores:
https://www.target.com/p/3m-extreme-mounting-tape-1-x60/-/A-14413487
I don't recommend getting it from Amazon or Ebay as they have a big problem with counterfeit product and you're likely to get some that LOOKS real, but has terrible hold.
#566 1 year ago
So I finished my spitfire mod and on heating the shrink tubing over the wires I melted my prop. going to order another now ...... so close. Didn’t even get to see it mounted and spinning In the game!
#567 1 year ago
Quoted from Gogdog:
There’s other flashers to use, left spinner flasher, lightning bolt flashers, pharaoh, they are all pretty active.
#568 1 year ago
Quoted from vireland:
Thanks...that looks exactly like what they use.
Good point....might play around with it on a different flasher...
That really sucks! I feel for ya man.
#569 1 year ago
Ok, finished the clairvoyant mod!
Thanks for everyone's help on this, especially dts .
Used the LEDs from Lighthouse LEDs. One nice thing is that they have moved the resistor further down the cable so the resistors are just about under the PF.
If I need to redo something in the future, I wouldn't reuse the 2 pico red LEDs that I used for the flasher. They are just too small. I would use 1 micro sized red led. Would be easier to attach to the agate ball and wouldn't have to splice 2 picos together. Plus.....one of my picos is now facing the wrong direction so the flash effect isn't as strong as it should be.
The hardest part was just getting the right pieces ordered. The wiring wasn't that hard, just a simple harness and then a separate wire that connects to some alligator clips from cometpinball.
#570 1 year ago
Quoted from Gogdog:
Looks great! You can experiment with different flasher colors and sizes and find the best fit. Nice to see that on the Pro, thanks for sharing!
#571 1 year ago
Finally installed my lighted speaker kit and acrylics...
#572 1 year ago
Quoted from PJKools:
Looks great!
I went with the two light system and I love them!
#573 1 year ago
Looks great!
Nice...where did you get the two-light setup?
#574 1 year ago
That translight is so much nicer than the stock Premium one!
-2
#575 1 year ago
Finally got the yellow acrylic back in stock, sorry for all the delays on the latest round of orders!
https://truecolorprotectors.com/products/iron-maiden-truecolor-plastic-protectors
Also, cool little note. All orders have been going out with a 3rd FREE slingshot spare in case one of yours ever breaks!
#576 1 year ago
I got it from speaker lights I had one set that used to be on my Ghostbusters I only needed to buy the second set plus the pieces to make it all up he calls it to yo dog kit
#577 1 year ago
Quoted from Fytr:
Definitely...couldn’t pass on it when I saw it earlier in this thread. I have it on a Pro though.
#578 1 year ago
First Peak, PINSPOT GRAPHICS!
We will have a few different graphics for Iron Maiden.
This is our Pinsot Graphic. It is a spot light that has a graphic that matches the theme of your game. This can be mounted under your game to shine under your game or in front of your front legs. The spot can also be pointed to above the top of your game to look like a topper. It can also be projected on the ceiling above you game. On this video it is hooked up to our optional photosensor control that will allow the Pinspot Graphic to be controlled my ANY light in ANY game. We have this Pinspot Graphic controlled “Aces High” light on the playfield. With supplied power tap, the mod with turn on and off with the game.
0114191739a (resized).jpg0115191812_resized (resized).jpg0115191813_resized (resized).jpg
#579 1 year ago
Quoted from Gogdog:
Went ahead and made a new cable extension that attaches to my flasher harness for the spitfire. Now I can switch between static 'on' or a flasher setup. Not sure which one I prefer more yet.
#580 1 year ago
Quoted from Litedpinballmods:
How have I not seen something like this before? Oh...its a sneak peak? So, how many other game graphics do you have this for, and price?
oh..and my kids have night lights kind of like this, and the insert graphics fade over time. Any chance of that happening with these?
#581 1 year ago
Quoted from Gogdog:
Thanks for the reply. You hit a nail on the head.
I will tell you, when in testing we had these on under a game, that was the first place people would walk, they would then kick at it with their foot, and we always got a very good comment. They do look very cool.
We have about 200 graphics in the system now, plan to have some listed before Texas. Some images work better them others, and we are adding to our selection daily. These will hook up to any game. Some of the graphics are generic, like the earth or the moon, which look cool on many space themed games.
The projector is small, 1 1/2" long. Aluminum housing to decapitate heat (it is warm to the touch, but not hot). Because it is so small and light that it easily mounts to under your cabinet or above with Velcro, only takes minutes to install. Because of our 4 lens system, it will focus at any length, but looks best at about 2 feet, longer then that you start getting light fade. We have designed it so if mounted under your game it will go from leg to leg. Looks good on most floors, light colored walls and ceilings. It will rotate 180 degrees so it can get pointed in any direction.
We have worked on this for about 8 months to do everything we can to limit fading. Different this, different that, cooling, coatings, many things, that has been our biggest challenge on this mod. Part of the problem was the longer we could get the image to last, the longer it would take to test. Their were times we had 20 of these pointed at walls running for a month. We have worked out that on this package you will get about 1,000 hours from fade. This is designed for home use, if your game is on an hour a day, the package will last about 3 years. We will sell replacement images that will give about 1,000 hours for $9.99. Only takes a few minutes to replace the image. The price will be $79.99, that includes power tap, mounting and enough length to mount any place on the game.
Dan
#582 1 year ago
Dan[quoted image][quoted image]
Yeah if new images are decently cheap, then fading isn't so much a problem.
Interested. I mean, could make a nice topper replacement, plus you can move it from game to game. Though I like the look on the floor too.
#583 1 year ago
A couple more
#584 1 year ago
Posted in the other IMDN thread but finished the pop bumper truecolor protectors
https://truecolorprotectors.com/products/iron-maiden-truecolor-pop-bumper-plastic-protectors
Of course one of my pop bumper light boards is out atm so only 2 are lit up in the pic
#585 1 year ago
The unlit pop is a flasher.
#586 1 year ago
Quoted from Billy16:
Then hooray nothing is broken
#587 1 year ago
Quoted from jrivelli:
Looks good I’m in but the link doesn’t seem to work.
#588 1 year ago
Awesome! Ordered.
Also note you are missing the leading "h" in your link.
#591 1 year ago
Anyone know where to order the premium LE figures now ? Stern Store seems to begone
#592 1 year ago
Quoted from mandelbloom:
You can do it through Stern if you call someone like Terry at pinball life with the part number, he will get a price for you and order them.
#593 1 year ago
This raises the issue of why nobody in the modding community has come up with replacement led boards for the pop bumpers that will make all three display GI level and also flash when required? This only flashing one pop bumper approach Stern took bothers me. As the original poster indicated makes it look like something is wrong with one of them.
Could use a Pi or something and read the inputs to the flasher LED and the GI led from 2 pop bumpers to determine the output light which would power all three...
#594 1 year ago
Anyone put a maiden figure behind the mummy shot?
Ive got peace of mind on the left and trooper on the right.
#595 1 year ago
Install some Pin Monk gel mods into my LE today. They have made the machine look the way it should have been from the start. Thanks vireland.
DSC_0018 (resized).JPGDSC_0026 (resized).JPGDSC_0017 (resized).JPGDSC_0024 (resized).JPGDSC_0020 (resized).JPGDSC_0023 (resized).JPGDSC_0032 (resized).JPG
#596 1 year ago
Those gels really do make a big difference. Major props to vic, especially on the cards inserts. getting those colors right is a PITA!
#597 1 year ago
Quoted from Thomo666:
[quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image]
Thanks for posting your install! Looks great down under, too!
#598 1 year ago
So I’m gauging interest in my orb mod. I’m starting a thread but am posting here as well.
I will have two sizes, 3/4” and 1”. Both look good to me so you can have your pick.
I’m including the necessary longer screw and spacers as well.
More details on the thread I’m starting but I’m thinking $30 shipped.
0CF3463A-382E-4F3D-9FA6-E6A3575A2862 (resized).jpeg29597DB1-9BCD-493A-B7C1-6AABCDF11D15 (resized).jpeg769CE2FC-6A4D-4952-A4BE-4BB921734110 (resized).jpegB13B8A0C-3280-4F8C-B007-C51552016FF2 (resized).jpegF854C0CC-8863-4CDD-B82E-1AB9F3805CA0 (resized).jpeg35FB049E-0729-4610-9828-CF0FF88DAB2C (resized).jpeg
#599 1 year ago
Looks cool but please can you explain how it works on the Premium. Does it use the light of the existing flasher? Thanks.
#600 1 year ago
It may indeed work on a pro but I do not have one to test/use. I do just use the existing LED that is under the plastic which normally faces down and I flip it to face up if you look at my iron maiden orb mod thread I have a little more detail and pictures
https://pinside.com/pinball/forum/topic/iron-maiden-orb-mod#post-4794079
3D MODS
$ 18.00
Top-Notch Target Shields
