Hi, good morning,
When I press the right flipper button, then the right Flipper don’t move , but the upper right flipper is ok.
The correspondent switch is ok. The right flipper coil is ok. So the mechanism of the flipper kit is ok
Changed the original coil stop for a new one.
No errors on the Alert issues.
When the pin is in atractive mode, the right flipper button doesn’t generate any sound but move the lcd info/images.
Already read the manual several times but can’t find a path to solve this issue
Already contacted Stern but their advice was to check the diagnostics for the flipper right switch and for the flipper right coil. Both are ok.
Please, if anyone had this problem, let me know what I must do to get the right flipper fires again. ( the upper right flipper is ok)
All the best
Miguel
