I just downloaded and installed 1.05. Had the verification run, successful install.
Powered the game off, removed the USB, and it booted up, but-
Got a message indicating that node board 10 not found. Game comes all the way up after a few seconds.
Opened coin door, service menu, technician alerts (not there before update)-
one is 'Check Node Board 10 not initialized. all test ok except 10 which is not responding. just above it is WS2812 Lamps only
Run the test but it's not responding.
Looked at the online manual- where is node board 10?
Played a few games and ran lamp tests. Everything appears to be running fine.
Turned the game off, came back a bit later, turned it on and same message.
I am missing something here?
This is the Pro Version FWIW....
