(Topic ID: 218758)
Iron Maiden 1.06 bugs, code issues, and code wishlist
By vireland
1 year ago
  • 565 posts
  • 130 Pinsiders participating
  • Latest reply 24 days ago by Flare
  • Topic is favorited by 39 Pinsiders
There have been 10 images uploaded to this topic. (View topic image gallery).
There are 565 posts in this topic. You are on page 7 of 12.
#301 11 months ago
New (?) bug in 1.03/4. I did a five way combo with the tomb treasure lit and the tomb treasure shot was the last shot. When I made the 5th shot to the orbit, it took the red tomb treasure arrow away, didn't put up the post or the tomb treasure animation, only showing the 5-way combo animation. I lost the Tomb Treasure.
#302 11 months ago
New issue I am first seeing in 1.04 (skipped 1.03!) - sometimes after the song selection is done and I plunge the ball, the song changes on me suddenly. It definitely didn’t used to do this, and when it does the screen is just showing the Eddie letter completion state, so it definitely feels weird/like a bug.
#303 11 months ago
My premium w/ flipper fidelity speakers sounds amazing now on 1.04, btw!!! On the old software I needed to put the balance way towards the cabinet speaker to get any bass, and to tweak the bass/treble settings, but no longer! Sounds great on default settings with minimal tweaks needed and the bass is rockin’ clear now. Looking forward to getting the same updates to my Aerosmith as well. If only the headphone output was as good - it’s definitely not super great sounding.
#304 11 months ago
Quoted from andre060:
Pro or premium/LE? This sounds more like a switch issue. I've been playing 1.04 extensively on a Pro and haven't seen this at all.
Nevermind. Saw the answer in your next post. I'd put it in switch test mode with the glass off and check for switches closing from vibration by smacking your open palm on the playfield firmly in different areas, then check that the shooter lane switch isn't triggering another somehow.
Then again, Prem/LE is different code than Pro. Do report back. Anyone else seeing this in a Prem/LE 1.04?
#305 11 months ago
This ...... love the game, like the band but am really tired of the same few songs to choose from
Long-shot Wishlist item:
Add 6 more Maiden songs that you can select to listen to while you are playing. Surely there must be enough storage available for this, and all you really need is a single graphic image for each song when it appears in the selection list. Zero impact on gameplay, etc. this should be easy.
need to add at least 10 -12 more songs just for the gameplay selections
#306 11 months ago
Quoted from vireland:
Will do. Seems really strange though, had no problems at all before the update, and after the plunge the song should be "locked in", so I'm not sure what switch would ever trigger the code to change songs... Anyway, I'll continue to investigate and report back.
#307 11 months ago
If the shooter lane switch is not working right, you'd be able to change songs while the ball is in play with the flippers until the first thing is hit on the PF.
If your shooter lane switch is bad, check the diagnostics to see if it's listed as bad in tech alerts and if so, what number switch is it saying the shooter lane switch is?
#308 11 months ago
I've also seen song selection change after the ball has been plunged once or twice in 50+ games. I'm on 1.03 still on my Premium. I'm not sure if it's a new bug or just rare.
#309 11 months ago
Quoted from Maide:
Good to hear it's not just me.
Since the song selection screen is disappearing consistently after I plunge, I'm thinking it's not the shooter lane switch... I'll check it to be sure, though.
#310 11 months ago
Quoted from Maide:
It was very common on early builds. I haven't seen it in a while.
#311 11 months ago
You know how this problem could be easily fixed? If Stern removed the ability to change songs after the game starts like they used to!
#312 11 months ago
Pro v1.04
Stack Icarus and Mummy MB.....Add a ball is not awarded. Mummy MB alone awards add a ball after hitting both ramps
#313 11 months ago
Quoted from Fezmid:
Actually they removed the ability TO remove the ability, to change the song, and factory setting has never been to not have it.
Personally, I could tire of a shorter song, if you are having a long game. They would just keep playing again and again.
I'm sure if it was just causing problems, and someone that has say in it really cares, it will be added back.
This reminds me of the AC/DC "why does the song always start over!!!" complaining.
In the end, it's gonna be whatever they want it to be, cause they made the game, lol
#314 11 months ago
Quoted from creepykenny:
That would be an awesome move by Stern. I wonder how much or if Iron Maiden would charge Stern for that. Might be cost prohibitive, but my goodness that would kick butt.
#315 11 months ago
I've said it before, sorta, but I wish they would make it easy to put YOUR music on YOUR machine. Especially when the music has no effect on the gameplay. Could be like a MAME or VP front end, a folder for songs and a folder for wheel images. And while we're daydreaming, I'd like a 3rd folder for playlists. Would LOVE to pick and album instead of a song.
And there's already USB connection.
#316 11 months ago
Quoted from earetz:
Pro v1.04
I do this all the time and it works to get the 3rd ball. However, I have had what you're describing happen once. Start Icarus, Stack Mummy, hit both ramps, no third ball. Is that what you're saying happened to you?
#317 11 months ago
Yes that is what i am saying. So maybe an intermittent bug.
#318 11 months ago
Quoted from earetz:
I'll put it back on the live bug list then.
#319 11 months ago
Quoted from Vader77:
Try this:
Put music attenuation at 60 and speech attenuation at -60. Then just crank up your stereo with whatever you like.
#320 11 months ago
Quoted from DNO:
True - but I wish they hadn't taken away the option. I don't get it.
#321 11 months ago
Long-shot Wishlist item: Add 6 more Maiden songs that you can select to listen to while you are playing. Surely there must be enough storage available for this, and all you really need is a single graphic image for each song when it appears in the selection list. Zero impact on gameplay, etc. this should be easy. need to add at least 10 -12 more songs just for the gameplay selections
Quoted from TigerLaw:
Would be amazed if Stern thought of this... and thus had the "background music" point to a different music file than the "Eddie Mode" music file. If so, then you could use Pinbrowser to change the "background" music however you'd like without affecting Eddie Modes.... Anyone know?
#322 11 months ago
Went from 1.0 to 1.4 this weekend and so far no issues.
Other posts have stated how much better the sound is but I wish I could agree.
While it has more bass, the rest isn't so great. Is there a adjustment feature I'm missing?
#323 11 months ago
Quoted from tiesmasc:
All the mode music is shared with the background music, except for Aces High.
#324 11 months ago
Quoted from mollyspub:
Pro or Prem/LE?
#326 11 months ago
What is current status of 1.03 and 1.04 in regards to DBV? I was gone on vacation and want to update our route game today but same a post on a FB group that both 1.03 and 1.04 cause issues with DBV working correctly?
Any idea/ experience with this?
Should I update code or wait till 1.05?
#327 11 months ago
Pro has dinky speakers compared to the LE. It's never going to sound better than okay/good. Change out the speakers and you'll hear an improvement.
#328 11 months ago
Thanks for clarifying that.
On another note...really liking the visual instructions in the attract mode. Thinking they shouldn't break it up with the high scores. It'd be better to get a complete breakdown on the objectives.
#329 11 months ago
I wonder if there will be a way for locations to put advertising in the new LCD screen. Like advertising for a discounted food combo if the pin is at a restaurant, etc.
#330 11 months ago
I have a tutorial on hooking an inexpensive external amp in the backbox of an Iron Maiden, and then hooking those to the larger speakers to give better sound, but I'm still waiting for some parts to finish the speaker install on a pro. The portion that shows how to make a connector to pull line-out audio off the CPU board to feed to the amp is up here already, though.
https://pinside.com/pinball/forum/topic/replacing-on-board-amp-with-external-amp-for-iron-maiden
#331 11 months ago
Quoted from treborlicec:
Yes! Stern definitely should follow JJPs footsteps in regards to the ability to upload a JPEG. It definitely a wow factor when people see the locations logo on the LCD, or as you've suggested a special perk. Please Stern!
#332 11 months ago
This happens quite frequently to me... And I had a very early build as I was one of the first in the chicagoland area to get a prem... Anything that I can do... The switch seems to be registering when the ball plunges out.
#333 11 months ago
Quoted from thePLAyNone:
Ohhhh that be cool... Could be a Dio's Arcade Banner picture up for my game... I think Maiden wouldn't mind.
#334 11 months ago
Quoted from Diospinball:
On a premium it's probably not the lane switch, but the newton ball. Have you upgraded yours so they don't misfire with vibration?
#335 11 months ago
I'd like to see profiles for settings.
Profile 1 - Tournament settings
Profile 2 - Free Play day, kids and rookies
Profile 3 - 2 for 1 day
Profile 4 - Other route location
3 button presses and done.
I do all of the above to several machines every week. Would save me some time for sure!
#336 11 months ago
Quoted from smokedog:
I'll put it on the wishlist, but it would require a fair amount of reprogramming of the shared system-level stuff.
#337 11 months ago
For sure. It would be awesome though.
#338 11 months ago
I've been asking for timed pricing for quite a while now, and that's a whole lot easier to implement. I think we'll both be waiting a while...
#339 11 months ago
HEHEHEHEHEH... I like it when they misfire from the vibration... The bottom one does misfire from time to time. But, is actually pretty accurate with the hits... So I think I'd like to leave that well enough alone...
The top one in the sarcophagus lock probably needs to be tweaked... As most direct blows don't register.
And what goes into upgrading them?????
#340 11 months ago
Upgraded to 1.04 tonight, and now it's randomly/occasionally spitting two balls into the shooter lane.
#341 11 months ago
There's a whole section in the Iron Maiden issues thread about it. You need to get a part from Stern and replace it on the newton ball. And, while you're there, replace the top switch in the lock with a rollover wheel trough-style switch (also discussed there).
#342 11 months ago
Quoted from Talon2000:
Likely a shooter lane switch on the edge. Try turning down your Trough Eject power to around 200.
#343 11 months ago
After a few tweaks my Iron Maiden LE plays perfect and I am very happy with the code.
This game is based on the Maiden comics and the handy game. With the battle against the beast it has an great end fight. And with it's ruleset and the game code it has a good story that connects all the different modes together. The story and animations reminds me of old arcade games like the old Mortal Kombat games. But why is there no intro for this story in the attract mode? Something that puts you in the world. After a defeat the hero Eddie has to collect his soul shards to fight again the beast. He got help from the clairvoant. There should be a text that explains the story just like the intro of old arcade games. It could be a comercial for the comics or the handy game in the attract mode. I think that would be realy cool or they could use the trailer for the handy game:
Or they could ask if they could use the first seven pages of the comic book as an intro. All this could be a good way to promote the comic and the handy game. And there won't be anymore asking of new players what this chick (clairvoant) has to do with Iron Maiden. It's a franchise, why don't they use it more?
#344 11 months ago
Quoted from Asael:
Or they could ask if they could use the first seven pages of the comic book as an intro. All this could be a good way to promote the comic and the handy game. It's a franchise, why don't they use it more?
Added the suggestion to the wishlist!
#345 11 months ago
Quoted from Asael:
Agree..
#346 11 months ago
Quoted from Asael:
Now this is a really cool idea!
#347 11 months ago
This may be a dumb question but where are you finding bass and treble adjustments in 1.04?
#348 11 months ago
Quoted from bigduke6:
Go to “utilities”, then select the “volume” menu. There are separate controls for the head speakers and bass speaker in the lower cabinet.
#349 11 months ago
Is it possible to get great sound out of the LE's stock JBL speakers with equalizer adjustments? Currently running 1.04 on factory settings and the sound is not great.
#350 11 months ago
Quoted from shock_me:
No, but if you add an external subwoofer its not bad.
Great American Pinball
