Quoted from foureyedcharlie:As a guy that does audio for a living, the thing that bothers me greatly is the lack of adjustments that can be made to the audio. You can't turn up the music for fuck sake..... you can slightly turn it up with the
-attenuation, but no where near enough. Attenuation is not volume! Totally different..... Google it. If you have music attenuation set at -60 and drain a ball, next ball starts with the song at a lower volume.... that is a bug. The attenuation sounds like they are using compression to attenuate and it blows. The whole audio menu is a bug. Everything is being attenuated behind the sound effects.....Ideally, VOLUME control for all three settings.... voice, sfx, and music. I want to be able to turn the music up on my music pins. I had more control of music volume on .97 Rant over
The music attenuation bug is still there in 1.0.2. It is really starting to bother me.
The stock sound mix is backwards from what a music pin should have. If I crank the volume it sounds like some *sshole is turning the music down everytime a sound effect is being played, and then back up. Super annoying. It should sound like a loud bar where Maiden is cranking at a nice steady level and you can hear the SF and speech “behind” the music, not in front of it.
Setting music attenuation to -25 is a nice setting for me but the lowering volume every ball is killing me. I have an LE in a home environment, details matter.
I feel like I could fix this bug in 15 mins. If I could access the code...
