Does anyone know IPB MM PF are any good other then Micro ?
I purchased an IPB playfield and it was nice, but I honestly think that they're probably down to seconds or thirds. I have also picked up a seconds playfield and I couldn't find an issue aside from a tiny flaw that would actually be under a ramp, so not visible. It was a great playfield.
The IPB playfield needs modification at the shooter lane and moat area to be correct. Chris Hutchins did a video on it once.
Quoted from o-din:The IPB playfield needs modification at the shooter lane and moat area to be correct. Chris Hutchins did a video on it once.
Is that true of all current stock? Because the two playfields I had were just fine.
Ok would you have the Video on that u can recall thanks for ant help
Quoted from jar155:Is that true of all current stock?
I couldn't say and the video is not on u-tube anymore, but there were modifications he showed that needed to be done on the ones he worked with to make them right.
Quoted from o-din:I couldn't say and the video is not on u-tube anymore, but there were modifications he showed that needed to be done on the ones he worked with to make them right.
Something important to consider. Thanks for the info. I think I remember that now, yeah.
I have a IPB MM playfield. I got mine right after they finished the first group of them way back when. The only issues I had were the super jets arrows up at the top of the outer loops were missing the purple on the outer edge of the arrows. There might have been a LITTLE touch up needed on the FIRE inserts too, but I can't remember how much. I sent mine to Chris at HEP to fix and re-clear so now it is perfect. Still haven't installed it....having too much fun playing it and taking it to shows! Bottom line is, if you have a blown out MM play field, either play field suppliers product will make your game look amazing!
Brian
This page was printed from https://pinside.com/pinball/forum/topic/ipb-mm-playfield and we tried optimising it for printing. Some page elements may have been deliberately hidden.
