Greetings Everyone,
It has been a while since we have posted any updates but now we have some exciting news to share. We have released Vers 3 of our shaker motor kits. At the moment Pinball Life has a limited supply, however we will be rolling out more stock that will be available with them, on our website, and here in our pinside shop over the coming weeks.
The Vers 3 Standard kits are fairly similar to the Vers 2 kits with some hardware improvements. WPC, WPC-95, Sys 11, and Gottlieb kits are now universal in terms of 115/240VAC. So those generations can be used internationally without any special voltage adapters.
The Vers 3 Premium kits are the ones that received a complete overhaul. We have developed a custom android mobile app that can connect wirelessly to the premium boards which will allow you to control a lot of parameters with the shaker motor. Within the app you can run a motor test, select which triggers you want to activate, and best of all.... create your own custom shake "Style"! Now you can customize how you want the motor to shake when it is triggered. Perhaps you want a slow smooth shake, or a fast rumble. You can even assign different shake styles to different triggers so that the motor shakes in sync with a particular gameplay event. The possibilities are pretty much endless. Visit our site for more details on the vers 3 boards.
Attached are some photos of the new boards as well as the android app. We hope you enjoy the new kits and continue to stay safe and healthy!
Best Regards,
Robert Goebel
Pinshakers LLC
www.pinshakers.com
