Fellow Pinsider's,
For the last few months I have taken a break from doing actual restorations. I've had several ideas floating around in my brain that wanted to get out. They have and here's a small sample of one.
I have created a Lamp Driver Test Fixture that can be used to assist in troubleshooting early Bally and Stern Lamp Driver boards. I'm attempting to make troubleshooting the early SS pins a bit easier, especially for a novice. This first product can be used in the game (using the machines built-in test function) or on a test bench (the latter assumes you know how to apply input signals to drive the lamps). This is not a completely new idea; it has been done before, albeit simpler. I modified it so that this test fixture actually simulates the load of the incandescent lamps. In this way, the SCR's see the same load as if in a game which can help spot a weak SCR that breaks down under load.
The premise is simple; the led bar graph will illuminate the respective led when the SCR (on the lamp driver board) is gated. A silk-screened chart (to the right of the led bar graphs) has three columns labeled J1, J2 and J3. Within those columns list the SCR (or Q#) associated with that J connector. Where the column contains an XX, that indicates no connection (no associated SCR). The alligator clip lead (which supplies power to the test fixture) attaches to the switched illumination bus (either on the backboard or on TP1 of the Rectifier board). This method will help narrow down where the issue with an "unlit" controlled lamp is; either on the driver board itself or in the wiring/lamp socket.
I have included a few pics and a short video below so you can get an idea of what it is and how it works.
[url]
[/url]
Right now I am gauging interest in this product to determine if there is sufficient demand to make more. I am in the process of putting the finishing touches on a Solenoid Driver Test Fixture and will offer that one soon. I am also in the second phase of creating another device that will work with these two boards (LDTF and SDTF) that will allow complete testing (on the bench) of the early SS Lamp Driver and Solenoid Driver boards.
If there is enough interest, I will ask for $40 shipped anywhere in the continental US. If the demand is higher then the price will go down. To get the pcbs manufactured will take approximately 10 days and then another 2 days for assembly.
Thanks for looking.
Phil
