I have one switch that is clearly open visually and tests open until the game has been played for a while and warms up. After about 20 minutes of playing, the switch starts scoring over and over intermittently. When this happens, I can immediately test it and it shows "half closed" if that makes sense. The 6803 control board test mode 94 (switches) will indicate two switches if one is closed. When this one is acting up it flashes 0, 13, 0, 13 etc. until you hold the rollover down and actually close the switch, then it flashes 13, 13, 13, 13. What the heck does that mean?
I assume I should start with a check of the pin on the control board associated with the right rollover target, but has anyone experienced something like this?
