(Topic ID: 103219)
Shadow Sanctum Wall Issue - SOLVED!
By Prosedsp
  • 34 posts
  • 8 Pinsiders participating
  • Latest reply 4 years ago by zucot
#1 4 years ago
I have been having a weird intermittent issue with the sanctum wall and sanctum kickout on my Shadow. It happens 50% of the time I am playing. Sometimes when I hit the sanctum the wall just drops. With the wall down I will hit the sanctum shot and it then kicks the ball out of the sanctum area instead of holding onto the ball and kicking a new one out of the shooter lane.
I have checked the switches behind the sanctum and they register fine in switch tests, replaced and rebuilt the sanctum wall switch. I have attached a video since I am sure I am not describing the problem as well as I could.
In the video the first ball lock acts fine, but then kicks the ball out from behind the sanctum. The 2nd time I hit the wall it drops immediately. At :19 you will see the wall drop when the ball strikes it, and again at :35. The multi-ball after the 3rd lock only put one ball into play.
Any thoughts?
#2 4 years ago
This may sound odd but check the trough optos.
#3 4 years ago
Quoted from Pinmeister:
They are all registering fine. Add a ball at a time and they all indicate closed when a ball is in front of that opto.
Also, I added to new balls to make sure there wasn't any magnitism affecting it.
#4 4 years ago
Check the sanctum switches in test by rolling a ball over them. Pressing on them can trigger when a ball does not. If so, adjust or replace switches as needed.
#5 4 years ago
I tried that and they all register. Ugh...
#6 4 years ago
Sweet new problem now (although they are probably related?) while making sure all connections were solid (games waspowered on) I lost the DMD all of the sudden. It boots up and gives me a single line (see image). I have a Rottendog board and the +50v light and +20v led are now off. Also, on the CPU security board the D20 led flashes (pic attached, but obviously you can't see it flashing). Periodically the game will reset and the D19 led will light up and then shut off.
Diagnosing board work is hard for me, so any help as to what will probably need replacing is appreciated!
#7 4 years ago
Check fuses for continuity with voltage tester.
#8 4 years ago
That's a bad noise when the ball locks. I might check the sanctum wall assembly switches to see if they are adjusted properly. If your optos are working at the sanctum, perhaps the game isn't seeing the wall fall and thinks the ball should not be in the lock. There's a switch at the bottom of the wall. Check it n test when the wall falls.
#9 4 years ago
Ok, I am an idiot. Re-seated all the cables in the backbox and the DMD is back up an running.
I am still dealing with the sanctum wall dropping when the ball passes the optos. Everything passes in switch test mode. All optos including sanctum and ball trough register. Any ideas?
#10 4 years ago
My machine when i had it didnt make that sound when you lock the ball at the sanctum. as Carl_694 said, check the wall assembly, or wherever that loud noise is coming from?
#11 4 years ago
Quoted from Carl_694:
Not a bad idea...but find out where that buzzing is coming from, it's not the magnet, you can hear the magnet hum when it's holding the ball, I think the buzz is coming from the diverter behind the sanctum, it maybe getting stuck when it's trying to lock the ball.
See the metal diverter...I bet this is what's getting stuck, you may need to rebuild it.
#12 4 years ago
Quoted from kvan99:
TS.JPG 265 KB
My shadow looked almost like that at one point!
#13 4 years ago
Quoted from kvan99:
TS.JPG 265 KB
Thanks for all the input. The worst part about this issue is it happens half of the time! Here is what I have checked out:
- Sanctum wall switch works fine, checks out in switch test (this is what I originally thought was the issue)
- The metal diverter kicks the balls out fine (that is the part you were referring to?), but I will take a look tonight and see if something strange is going on with it under the playfield.
- All "lockup" switched behind sanctum wall check out fine, however using voltmeter the middle lockup is showing me 635 when the switch is depressed, while the left and right are showing 735. I am planning on replacing the diode on the middle switch.
I believe the buzz is the sound of the playfield plastic vibrating on top of the left sanctum opto, but will re-confirm. It is weird, I always thought that was a normal noise since I haven't played too many other Shadows!
My next thought is to replace the Sanctum optos. They pass all tests, but perhaps they are starting to get flaky?
Thanks again for everyone's help, any ideas are always appreciated!
#14 4 years ago
Quoted from kvan99:
TS.JPG 265 KB
that looks more like a "The Sadow"
#15 4 years ago
I have no idea whose Shadow that is...I picked it up on the internet to help illustrate.
#16 4 years ago
And you are sure the bottom switch on the wall is ALWAYS being made when the wall drops? I had to bend the arm when I replaced that switch. Did you?
#17 4 years ago
There is also, if I recall, armature that can wear prematurely. Check out this thread. I had to replace it on mine. https://pinside.com/pinball/forum/topic/the-shadow-wall-drop-target-stuck-up.
#18 4 years ago
I just watched the video again, the machine knows when the 3rd ball is in the sanctum and it starts the multiball with only the one ball, so I have to say your machine thinks it's missing 2 balls....You need to take the balls out and put them in one by one in the switch test and make sure it's registering in the switch test matrix.
Also it happens 50% of times is because that's how trough optos go bad..they start working intermittently then eventually cut out. Here is an easy way to check if you have a flaky opto, put the game in the switch test and take the balls out, then with an open hand slap the pf and see if the switch matrix registers a switch from the shock. Let me know how this plays out..............
#19 4 years ago
Quoted from kvan99:
That is a great idea! I will try it and let you know how it works out. Thanks!
#20 4 years ago
Quoted from kvan99:
Ok! I agree with your diagnosis, but your prescription is a little opiated for this patient!
If trough optos haven't been replaced, I always recommend replacing them all on both sides. This costs less than $5, and takes about 15 min. Don't buy replacement boards with SMD's as down the road, they seem to form the problems again, but faster (I'm guessing due to surface mount parts being more prone to vibration over through hole parts, with more strength).
The video really suggests to me though that the ball is maybe engaging the first and second sanctum lock, possibly sitting over the second lock switch partially, and never making it completely in.
I would concentrate there first, and look to the troughs after. Your eyes are you best tool for PF issues.
#21 4 years ago
Quoted from Atomicboy:
Opiated? Lol...ok. Funny but still wrong, if the diverter is kicking the ball out, which means then it know the ball is in the sanctum so the switch idea doesn't hold water. The only way it will kick the ball out rather than lock it is if it thinks theres only one ball in the machine. Besides if the switch was not fully engaging it would first go into ball search then kick out the ball...if you watch the video it shows the ball releasing from the sanctum immediately.
#22 4 years ago
I'll have to check mine, but it's common for physical locks to kick a ball out if it believes there are one too many in there. It may be the troughs, but as I stated, I'd be looking to the lock area very closely first, then redoing the trough optos before slamming my hand on the PF
If fact, I would never be slamming my hand on any of my PFs.
#23 4 years ago
Then good luck fixing intermittent opto problems..I guess shot gunning parts is much better.
#24 4 years ago
Quoted from kvan99:
It's not shot gunning for troughs. If one is ready to go, others are too. I used to spend all kinds of time with a digital camera finding the one issue in a trough, only to have another go a few weeks later. There is so much vibration there, that the best way to tackle troughs is the pull both sides and replace all emitters and receivers, and reinstall with small post rubbers between the screws to lessen the vibration.
It’s more of a rebuild than a shot gunning approach, and produces rock solid troughs for years after. I have never had to deal with another trough issue to date from doing this method, where before when looking for a single issue, another always cropped up sooner or later. This method came from experience, but hey, maybe you enjoy doing repairs over playing more than I.
Anyway, I don't provide assistant to people to get into back and forth issues. There are enough things for the op to try here, one of which should resolve the issue. I would only recommend staying away from slapping the PF, but what do I know
#25 4 years ago
Thanks for everyone's advice, I really appreciate the fact that fellow Pinsiders are so eager to share their fixes and troubleshooting ideas! I won't get a chance to work on the pin till early next week, but I will make sure to follow up and let everyone know how the progress is coming. You all have given me a good list of tests to perform, and I look forward to getting this issue fixed once and for all.
Thanks again everyone!
#26 4 years ago
Quoted from Prosedsp:
Unacceptable! We need a resolution! J/K
#27 4 years ago
Great except you quoted my post and said that it was opiated, and then proceded to give the wrong advice of stuck switches, and criticizing slapping of the pf..which by the way is much softer on the pf than flying steel balls.
#28 4 years ago
#29 4 years ago
So just for my own piece of mind (not that I needed it, but...) tested the sanctum locks with something triggering the lock two when there are not two balls in there, and in fact you get exactly what you are showing in your vid. Again, I would try that first, readjusting this switch to less/more sensitive first before looking to the troughs.
I have seen this before with my friends machine. it may not be it in the end, but again, easiest place to start, and after that, I would move to the trough, although with all my testing there I could not produce a situation where the sanctum spit out a ball right after one entered as with yours.
#30 4 years ago
Hi everyone, sorry it took so long to update this thread. I think I fixed the issue, and as usual it was a much easier, basic fix than I was expecting.
Atomicboy was correct! The middle lockup switch was getting stuck on the right lockup switch. So when the first ball would lock it would engage the middle switch on its way to the right. The middle switch was getting stuck on the right switch and staying down, tricking the machine into thinking there were two balls locked. Adjusted the middle switch and presto, works like a charm!
Thanks again for everyone's advice, I really appreciate all the help and knowledge I received from you all!
#31 4 years ago
In that case my tip of the hat to Atomicboy. However, I thought you said that it kicked the same ball out without ever locking any....which made the stuck switch idea wrong. If the machine locked the first and then it triggered 2 switches then it would have started multiball with 2 balls not 1. Also easily the switch test would have indicated 2 switches closed on the martix, which would have tipped you off of a stuck switch, (thought you said you did this) but whatever. Good luck.
#32 4 years ago
Quoted from kvan99:
Yeah I ran a switch test several times. I was only having the issue pop up randomly and the switch wasn't staying stuck every time. Had it shown up during a test my problems would have been solved easily! Again, thanks for all the help.
#33 4 years ago
Glad it worked out.
1 month later
#34 4 years ago
So does your machine still make the same noise or no? I have a noisy sanctum lock but no frame of reference for if it's normal.
$ 29.50
Playfield - Plastics
Bright Lights Pinball
PCB Emporium
$ 59.00
PinSound
KAHR.US Circuits
4,800
Burlington, WI
$ 50.00
Portland, OR
$ 229.99
3,250
Saint Petersburg, FL
Pin Mods
$ 159.99
$ 129.00
LED OCD
$ 40.00
$ 29.99
$ 59.00
