(Topic ID: 77993)
Intermittent displays on Firepower
By Tridentphoto
5 years ago
  • 6 posts
  • 5 Pinsiders participating
  • Latest reply 5 years ago by Tridentphoto
#1 5 years ago
Seems like my displays are wigging out on me. When I boot the machine the player 1 is usually ok, but the other 3 are sketchy, sometimes only displaying part of the scores. then after it warms up they seem to get better. What would cause that?
I am thinking it must be a power issue, but what component would change its capacitance/resistance/other when used, and the displays sometimes lose the first digit on the player 2 and 4, but a Fonzie slap to the header sometimes brings them back.
Ideas? What should I be testing for?
Jeff
#2 5 years ago
replace the IDC connectors at top of MPU board. this cured a similar issue on my black knight
#3 5 years ago
Wiggle the 1J4, 1J5 and 1J6 at the top of the CPU board when the displays are misbehaving to see if movement there changes the displays. Re-seat the connectors on the master display board and each of the slave displays (with the power off). Let us know what happens.
#4 5 years ago
In addition to reseating the connectors at the top of the MPU board, you can also swap the display around to see if they have the same problem in a different position. I would first take the good player display and try it in every position. If it works correctly at P1-P4, you know the MDB is ok and the problem is more likely one of the slave displays. Then add the second display and see if has a problem in the remaining three positions. If it does, put it aside and do the same with the third and fourth. If you add a display back and it's good, then try adding the next one.
You should also check your display voltages to make sure they are correct. You can get schematics here:
http://firepowerpinball.com/
Quoted from Tridentphoto:
This would indicate that the displays have outgassed and after being on for a bit and warming up work correctly. The only solution to this is to replace the display.
viperrwk
#5 5 years ago
Mine acted very flaky and I changed all connectors and no difference. Finally after a year the machine locked up and would not start. Replacing the PIA that drives the displays fixed not only the boot issue but also the displays.
#6 5 years ago
Thank you all for the input. I'm thinking it may be a connection issue, because while doing a solenoid test today they would sometimes flicker on all 7s when the solenoids triggered. I hope to fiddle more tomorrow.
Thorndale, PA
$ 279.95
$ 22.00
$ 17.00
Yorktown Parts and Equip
$ 399.95
Siegecraft Electronics
$ 14.00
$ 48.00
$ 49.00
