So I repaired the diodes on a wpc95 board. The LED at 104 (flashers) is dead but the test point is 22.1v. The exit to the playfield is 22.1 so the flashers are getting power. All new bulbs installed. The interlock switch; when you pull it out doesn't override the power cutoff. Basically pulling it out doesn't allow power to the flashers or solinoids. Tells me the switch is bad. Can the interlock not functioning properly cause the led and the flashers not to work, even if the door is closed?
