So the sound board on Dragon recently started blowing capacitors in explosive fashion. It is also taking out the associated diode. I tested the components and found one transistor that didn't measure propely but I'm not sure if that could cause the issue.
The blown components come off lines 29 and 30 which I believe is the coil voltage if I'm understanding the schematics.
Any help would be much appreciated.
