You need the server files on a separate computer which is connected via ethernet to the p2k.
The separate computer must have python 2.7 installed. Thats all.
Quoted from Ahoernchen:You need the server files on a separate computer which is connected via ethernet to the p2k.
OK, im an idiot..... just went back and re-read the post. What is the python server for? The port issue?
I do run dd-wrt on several routers i own and can forward the ports properly using these (assuming that is what the issue is).
BTW neither of your sites appear to be working:
http://pinball-tournament.dyndns-at-work.com/indexe.html
pinball2000scores.org (expired domain)
So i cant look at the setup information.
Quoted from lurch:BTW anyone looking to do this.....
The network card is available for $15 right now on ebay!
ebay.com link
Thanks! Just picked one up...
You tried the old domains, this is the actual working domain:
http://pinball-tournament.servegame.com/indexe.html
or
http://pinball-tournament.servegame.com/all.html
I heard a guy in California has the only Wizard Blocks P2K prototype and he's got it wired and hooked up to the server. Seems like nobody can touch his high score on Wizard Blocks.
Quoted from littlecammi:I heard a guy in California has the only Wizard Blocks P2K prototype and he's got it wired and hooked up to the server. Seems like nobody can touch his high score on Wizard Blocks.
LOL! Id love to play it just once. Just watched "Tilt: The Battle To Save Pinball" really makes me sad this never saw the light of day. Even sadder that as a pin2000 owner, i cant get a playfield to slide in my RFM cabinet. Would be sweet if someone could do a limited run of these and released the firmware. Id even be fine with a whitewood playfield.
Quoted from lurch:LOL! Id love to play it just once. Just watched "Tilt: The Battle To Save Pinball" really makes me sad this never saw the light of day. Even sadder that as a pin2000 owner, i cant get a playfield to slide in my RFM cabinet. Would be sweet if someone could do a limited run of these and released the firmware. Id even be fine with a whitewood playfield.
I've played it. It is unfinished and needs a LOT of work on the code still. However, there is still hope I am told. But I wouldn't hold your breath.
Pascal-
Can we connect to your server without the Python server?
1) configure machine to:
Tournament Play: YES
Configure IP: Whatever local IP/DNS/Gateway
Tourney IP Address: 84.143.103.225
2) Configure port forwarding on local router for UDP/2069, UDP/23, UDP/8080
Will this work? Is the Game ID a MAC address?
Anyone heard from Ahoernchen????
You alive buddy?
Im trying to get this thing connected and need some help!
Anyone else running a tournament server? Any possibility of me getting my hands on this software? I have a server laying around i could setup for this!!!!!!!!!
So this is still going on? Would love to jump on this once we get ours running more reliably. Figured I'd swap out the RAM as long as I'm trying to fix the thing.
Quoted from Poopiehead:So this is still going on? Would love to jump on this once we get ours running more reliably. Figured I'd swap out the RAM as long as I'm trying to fix the thing.
I'm not having much luck. I'm not able to pull the high scores list. I heard from Ahoernchen via PM once that he added my MAC address, but no other luck; I get the tournament screen, but no player list or scores Would love to play it.
NoIPResolve for pinball-tournament.servegame.com expired yesterday . Do someone has the current server ip or can restore the NoIpResolution ?
Do somebody can share ServerEN and ServerDE.rar ?
Thanks in advance.
My bad! my nameserver did not resolved it !
This page was printed from https://pinside.com/pinball/forum/topic/interest-in-pinball-2000-server/page/3 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
