(Topic ID: 228185)
interest check: run-dmd clock (winter 2018 batch) - sold out
By j_m_
1 year ago
  • 183 posts
  • 41 Pinsiders participating
  • Latest reply 1 year ago by j_m_
  • Topic is favorited by 20 Pinsiders
    There have been 29 images uploaded to this topic. (View topic image gallery).
    There are 183 posts in this topic. You are on page 1 of 4.
    #1 1 year ago
    I'm checking to see if there is enough interest to run one more batch for the holidays. the thought is if I get 20+ people within the next two weeks that I might be able to order and have the components in time to assemble and ship these prior to xmas for those that want to give them as gifts. like the previous batches, the number of clocks is limited to 24 people max
    clock description:
    assembled using custom laser-cut acrylic panels, the clocks use (2) two P5 sized rgb LED panels, which are mounted side-by-side to display the 128x32 dot resolution (just like a pinball DMD). each clock measures approximately 28.00" (w) x 7.50" (h) x 1.50" (d)
    although the clock can only display monochrome colored animations, the user has the ability to select between one of 7 colors (red, green, blue, yellow, magenta, teal or white) by toggling the six dip switches accessible from the backside of the clock (see below for legend)
    the clocks ship ready to mount on the wall (with 2 hanging holes [16" on center]) or can be placed on a shelf or desktop. only a small amount of assembly is required (to install the front panel using the enclosed hardware and tools
    the front, transparent gray acrylic panel is shipped with the protective paper still attached on both sides to prevent any accidental scratches during transit
    featuring a custom designed, laser cut acrylic front and rear panels, the front is a dark transparent grey (to neatly hide the internal components when the clock is not powered on) and the rear panel is black with material that has a glossy front side and matte back side (to help reduce/eliminate fingerprints).
    custom cut-outs in the rear panel allow access to: CR2032 battery, the power cable port, a 6-pin ICSP header to facilitate updating the run-dmd pc board's firmware and the 6 toggle switch block to change the clock's display color
    color selectable dip-switch settings:
    on-off-off-on-off-off = red
    off-on-off-off-on-off = green
    off-off-on-off-off-on = blue
    on-on-off-on-on-off = yellow
    on-off-on-on-off-on = purple
    off-on-on-off-on-on = teal
    on-on-on-on-on-on = white
    on - up, off - down
    information regarding how to adjust the many options found in the clock can be found here:
    http://www.phosphors.com/run-dmd/Run-DMD_v3.54_Menu_Navigation.pdf
    a youtube video on how to properly install the CR2032 battery can be found here:
    the cost per clock is $450 plus shipping, and each clock includes the following:
    - a mostly assembled run-dmd clock
    - (1) CR2032 lithium coin battery (to store all user defined settings and keep time when the clock is powered off)
    - (1) 5v, 10a power supply to power the clock with a 6' grounded 3-prong cable (north american standard)
    video of retromanIE's clock from the batch 5
    from turbo20lbs
    from tuna delight
    NOTE:
    please take the time to read the .pdf user guide linked above prior to attempting to change/adjust any of the clock settings (especially the ones under the TOOLS menu option
    PLEASE READ the NOTE at the bottom of this post PRIOR attempting to modify the settings of your clock
    activating the "detect DMD" option will attempt to re-detect the various compatible dmd panel types connected to your run-dmd pc board. if your panels are working correctly, you DO NOT want to select this option
    NOTE 2:
    if you turn off the clock prior to selecting a new display type, your clock will not display correctly the next time you power it up after selecting this option. if you do select this option, you need to go through the process of re-selecting the correct display type (by pressing and holding down button 3, while powering up the clock and then waiting for the display types to begin to cycle and confirming the correct display type with button 4
    the software required re-image your SD card using hdd raw copy
    http://hddguru.com/software/HDD-Raw-Copy-Tool/HDDRawCopy1.10Setup.exe
    NOTE 3:
    DO NOT attempt to read the SD card in your computer. due to the nature of how the information is [blindly] written, your computer will report that the card is not formatted. DO NOT format the card, otherwise you will lose all of your settings and animations stored on the SD card
    >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> READ ME <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
    have a clock that is displaying 2/4 bright horizontal lines when powering up and nothing more?
    - eject and re-insert the SD card to ensure that it is making connection in the card slot on the run-dmd pc board
    have a clock and are experiencing either corrupt or no animations? check out this thread:
    https://pinside.com/pinball/forum/topic/run-dmd-clock-reflashing-the-sd-card-to-fix-glitched-no-animations
    shipped: 2018.dec.07
    Pinballer73, Wmsfan, speederice, Tsskinne, NimblePin, nitrojcrawf, jzach, swinks, MGM2, fattdirk, DanT, Phat_Jay, BlueIrocGuy, rviguet, jfesler, KloggMonkey, bintzknocker, MrKegFlex
    shipped: 2018.dec.08
    Maleko, a non pinsider (hand delivered)
    shipped: 2018.dec.10
    ReplayRyan, Ilushka85
    shipping 2018.dec.14
    Dane186, GravitaR (hand delivering)
    last updated: 2018.dec.14
    #2 1 year ago
    Rock on!!
    Very Nice of you to do another Batch.
    These Truly run the Line of being Museum Pieces, The countless animations are a Blast!
    Best Clock Ever!!!
    #3 1 year ago
    Quoted from Ericpinballfan:
    Best Clock Ever!!!
    You can say that again!!
    #4 1 year ago
    Please add me to the list, I'd like one.
    #5 1 year ago
    bumping the post for those that may have missed the announcement
    #6 1 year ago
    Hey j-
    Please put me down for one. Cheers~
    #7 1 year ago
    Interested!
    #8 1 year ago
    Bump as I'd like to see it happen.
    #9 1 year ago
    Count me in j_m_!
    Glad to see you making them again.
    My wife will be pretty stoked.
    #10 1 year ago
    I’m in.
    #11 1 year ago
    Hopefully a few more will join the list. How cool would it be to have a clock on your desk, in the family room or beside the bed running DMD animations!
    #12 1 year ago
    I'd be in for one!
    #13 1 year ago
    bump for the afternoon crowd
    #14 1 year ago
    very, very tempted .....
    are the graphics from the bally, williams era as well as the stern ones shown ?
    #15 1 year ago
    I bought one of these in the last batch not knowing what to expect. All I can say is WOW.
    It runs 24/7 and everyone that sees it is blown away.
    The OP is great to deal with and his follow through is incredible.
    You can buy this item with complete confidence.
    Thanks for making a killer game room "must have"!
    #16 1 year ago
    Agreed. Buy with confidence. A fantastic product from a solid Pinsider.
    #17 1 year ago
    Quoted from swinks:
    bally, williams, data east and stern
    #18 1 year ago
    Quoted from j_m_:
    Cool, always wanted one, count me in
    #19 1 year ago
    These are very cool....my question is how much end user work is required or is it plug and play? Im interested but I don't need another time consuming project
    #20 1 year ago
    Quoted from PtownPin:
    Plug-and-play set color set time.
    #21 1 year ago
    I preset the color to purple or white on all clocks (to ensure that everything is working on the RGB panels.
    all you have to do upon receipt is insert the battery (which I may do on this batch, since that appeared to confuse a few people) and attach the front piece of acrylic (I ship it with the protective paper still on it so that risk of it scratching during shipping is reduced/eliminated). this entails attaching 6 nylon posts with 12 screws (6 stainless for the rear and 6 black oxide for the front).
    setting the time is accomplished by entering the menu and changing it from the very first screen. all of the menu option information can be found here:
    http://www.phosphors.com/run-dmd/Run-DMD_v3.53_Menu_Navigation.pdf
    #22 1 year ago
    I like it....anyone have any actual photos of the finished product? Its hard to see in the video as it so dark
    #23 1 year ago
    Definitely interested!
    #24 1 year ago
    I've added 2 photos to the first post of what the finished product looks like
    edit:
    the list has now made it to the 1/2 point for me to order everything and commit to offering up another batch
    #25 1 year ago
    Thanks for posting the pics....so how is the clock powered? The photo with the clock hanging on the wall would indicate that its powered off standard batteries? Is this correct? If so how long do the batteries last?
    #26 1 year ago
    It comes with a power adapter and needs to be plugged in.
    #27 1 year ago
    Quoted from gweempose:
    ok thanks
    #28 1 year ago
    Just so people are aware it isn't just the size of a standard DMD which was what I thought before I saw one of these in person at a friends house, its like 4 DMDs put together or so I think. Anyway just letting people know in case anyone else has the same thought I initially had.
    #29 1 year ago
    from the initial post: each clock measures approximately 28.00" (w) x 7.50" (h) x 1.50" (d)
    the clock is powered by a 5v, 10amp power brick which is included. I believe that cord length that terminates to the clock board is approximately 3' in length and the other end is approximately 2-3' in length (that end is a standard 3-prong extension cord just like a desktop computer cord
    #30 1 year ago
    Quoted from j_m_:
    Thanks for the information....just to be clear the power cord is exactly how long? I'd like to mount close to the ceiling, which would require an 8-10' cord....
    #31 1 year ago
    I was going to ask the same thing, so with the brick I can then locally grab a kettle lead to suit 240 volt power supplied or is it a 120vdc power brick?
    #32 1 year ago
    this is the power brick used. I believe that since its a switching power supply, those outside of north america just need a different cable going to the mains
    #33 1 year ago
    Thanks for the pictures....this power brick solution seems ideal for a desktop application
    #34 1 year ago
    I was so impressed I took a video for others to see. I highly recommend this amazing clock!!
    #35 1 year ago
    47DE34F5-A5DF-44F6-AA86-353EF3C4F690 (resized).jpeg4EC3F4F8-692B-493F-B8A4-5F7F8996BFCE (resized).jpeg582B5A75-5BCE-4DDA-87DF-6DF368498503 (resized).jpeg
    #36 1 year ago
    Quoted from TheHueManatee:
    You know you can turn the blinking red light off????
    #37 1 year ago
    Yea I did after JM told me in the last thread
    #38 1 year ago
    Put me in for one. I've procrastinated almost to long. Thanks goodness another batch will hopefully be made.
    #39 1 year ago
    Quoted from j_m_:
    excellent thanks heaps for sharing j_m_
    #40 1 year ago
    Count me in for one, thanks!
    #41 1 year ago
    Weekend bump
    #42 1 year ago
    I"ll take one. Add me to the list.
    #43 1 year ago
    2018.nov.10 update
    against my better judgement, I've gone and ordered everything to ensure that I can get these done prior to the holidays
    with only 10 positions left on the list, if you've been on the fence about ordering one from me, the time to make your decision is running out
    #44 1 year ago
    Please add me. I’m interested.
    #45 1 year ago
    Please add me, I’ll take one, thx!
    #46 1 year ago
    I’ve looked at this one long enough, please put me on the list!
    #47 1 year ago
    Add me to the list as well.
    #48 1 year ago
    I’ll take one please.
    #49 1 year ago
    Add me to the list please.
    #50 1 year ago
    I bought mine in 2015. A little smaller back then at 24'' x 7''. I love it in my game room. Note that this isn't perfectly silent. There is a quiet high pitch sound when a large graphic comes across the screen. If I'm sitting quietly in the room (reading a book or working) I will turn the clock off but if you have a TV or pin on at the same time it won't bother you a bit. Nothing that will make you go mad but the reason I haven't bought a 2nd for my office (where it would be amazing) because quiet in there is really helpful.
    I turn mine on only when my MET is turned on at the breaker so it doesn't have a lot of hours on it. BUT, 3 years and still works perfectly.
    Enjoy!!
    (If you discount well for repeat business MAYBE I could consider for the office!!)
    $ 999.00
    $ 19.95
    $ 69.99
    $ 54.99
    $ 1,000.00
    Playfields
    Pinball Playfields
    $ 17.50
    Pin Monk
    $ 64.00
    $ 74.00
    Id Rather Play Pinball
    3D MODS
    $ 209.99
    PinballBulbs
    Pinball Wheezer
    $ 54.99
    COINTAKER.COM
    $ 75.00
    DBC Pinball
    $ 7,299.00
    Classic Game Rooms
    $ 299.99
    $ 4.00
    Back Alley Creations
    $ 7,000.00
    Arizona Pinball
    $ 76.95
