Video:
[[No permanent modification]]
This mod replaces the factory Living Dead Girl panel with an enclosed Mausoleum for an infinity mirror lightshow that pops.
It installs with the factory bolts and supplied clips (they hold tight and install with no hassle). The lighting is triggered off of the factory lights via a photoresistor and transistor in the circuit, installed with two of the factory screws over the original light board (this is a custom 3d print that fits perfectly flush over the board). Wiring is attached to the 12V at the bottom of the cab and easily fed up alongside the factory wiring for the LDG (wiring is separated with a quick release plug). The excess wiring and lightboard assembly hide up in a reservoir in the Mod out of view.
Extra clips and an extra lightboard backing will be included just in case, but I haven't had any failures in testing.
