MEZELmods would like to announce our upcoming undercab LED kit. The beta test version should be released by end of March, beginning of April. Here are some details.
1. Price point less than $100.
2. Compatible with Stern SAM systems (23 machines), Sega Whitestar (14 machines) and Stern Whitestar (16 machines).
3. Utilizes all flashers and low current powered devices (ex: MET rising grave marker) using the signal from the backbox.
4. Currently uses 6 colors each of single color 5050 SMD LED strips (Red, Blue, Green, Yellow, Purple and White).
5. Customer choice of what colors to associate with each flasher and low current powered devices.
6. Each color strip will be 1.5 feet long with 27 5050 SMD LEDs each.
7. Option to add more colors when available, such as orange, pink or light blue. Can be added to an existing install.
8. Can be removed and put on any other of the above systems, colors can be reassigned to match new machines color scheme
9. Separate components for easy removal when using a lift.
10. No soldering, all plug and play
11. Simple instructions to pick your colors and quickly setup up the LEDs as you prefer. Can be experimented with to get the look you want.
Looking for feedback while we are finalizing this product.
