I've just started collecting less than a year ago. My Pins are in my basement and I'm in the Midwest. Is is a fairly common occurrence for sump pumps to stop working(or septics to back up) and flood basements. I had decent coverage without the pins and once I've added in the Pins there is not a lot left to cover the home in the event that water comes in.
My regular coverage will take care of everything else on the home and pins(fire, theft, storm damage, etc), just having a tough time figuring out an affordable way to cover the pins in the event the sump pump stops working. This seems to be the hole in coverage. For example, if the basement flooded it might cost$25,000 and if there is 8 pins valued at $48,000 my coverage is capped at $50,000. I would be in a bad spot. Are there separate companies like cars to insure for this specific event? I do have a back up pump, battery.
Any thoughts on places to cover these specifically.
