(Topic ID: 36470)
Instructions Needed for Creature Transparent Backboard Mod
By Fatsquatch
11 years ago
  • 27 posts
  • 7 Pinsiders participating
  • Latest reply 11 years ago by toddsolus
#1 11 years ago
I just picked up this mod for my Creature, but have no installation instructions.
Does anyone have any protips on how to remove the original backboard and install the new one?
Vid of the mod installed:
#2 11 years ago
I got it all figured it out on my own, but in case anyone else needs help with this mod in the future, here's what I did:
The original backboard is glued and stapled at the top, and I was able to remove it (without damaging it) by simply holding the board at the bottom on both sides and carefully wiggling it back forth. Once the original board was out, I removed the staples that were left hanging down so they wouldn't be in the way of the all-plexi replacement.
To mount the new backboard inside the cabinet, I'm currently using cardboard shims on the sides to hold it in place, but will replace those with velcro strips when I pick some up.
To power the 12v LED strip, I soldered wires to the coin door board in section J4 (pin 1 for ground, pin 4 for 12v as is printed on the board).
The LED strip that came with the mod proved to be too bright and long, so I replaced it with a smaller strip of 6 LEDs that I centered around the sun in the backboard's image. The brightness level is just right, and it with the strip mounted near the top of the backbox, it does a good job at giving the effect of a sunset.
These pictures don't quite do it justice, as with the flash off (pic #1), it looks like the LEDs are washing out the image. In-person, it looks far better, with nothing being washed out or even spotty-looking. (Using the LED strip holder that came with the mod, my smaller LED strip sits off the backbox enough that the LEDs don't create any visual hotspot effects.)
#3 11 years ago
Looks sweet dude. Where did you get the mod?
I've just finished a full rebuild on a Creature and like the look of that.
I also want the tail light mod for the upper board at some point, but there doesn't seem to be anyone left selling them.
Cheers.
#4 11 years ago
Quoted from Muppet_Man:
Cheers.
There is
But you will need to find the thread as he may have a few spare from his latest run. They are great as I got one from him.
#5 11 years ago
Looks sweet dude. Where did you get the mod?I've just finished a full rebuild on a Creature and like the look of that.I also want the tail light mod for the upper board at some point, but there doesn't seem to be anyone left selling them.Cheers.
I have never seen one of these in person, so I'm not sure how it compares, but I put a cold cathode UV light above the panel which lights it up very nicely due to the fluorescent paint.
#6 11 years ago
Hi Alveolus. Do you have a photo? It's sounds interesting.
Cheers for the headsup on the other mod Shapeshifter. I found the post and have joined the queue.
#7 11 years ago
There's an Australian site that sells them, but I sure as hell can't remember which site that is.
If I recall correctly, the mod costs $200+. I bought mine from a friend who had picked it up for $50 as part of a package deal he recently made. He sold it to me for what he had paid. I really lucked out!
#8 11 years ago
I can try to take a picture of it tonight. Could save you $190 if yOU like it.
#9 11 years ago
£35.00 ($50.00) was a bloody steel. Nice one.
I'll look forward to the photo.
Cheers chap.
#10 11 years ago
Quoted from Fatsquatch:
You must be friends with Scott
Steve
#11 11 years ago
Hehe. Yes, sir!
He's a great guy, for sure.
#12 11 years ago
Sorry I'm tardy Here are the photos. First one shows the effect with all the lights off. Second one is shot in attract mode.
#13 11 years ago
here's a link to this mod on the site, and yes, it's $200
http://mrpinballa2.cart.net.au/details/2901603.html
#14 11 years ago
That is a VERY nice mod indeed. Are you saying this is just a really cheap UV strip light? What size was is you got in there and what did you run it off of?
Cheers chap.
#15 11 years ago
I used a 12" cold cathode UV light. But that was before the proliferation of LED lighting options. Probably an LED strip light would work as well and be an easier install. I just ran wires into the backbox and took 12v from the driver board.
good luck,
Shawn
#16 11 years ago
I realy like the UV look. I'm not sure if there is such a thing as a UV LED, I try and find out.
Cheers
#17 11 years ago
hey there Alveolus would you mind posting more pictures of the light tube, how you connected it and close ups of the board connection. I just got a creech and look forward to modding it. I know little about the circuit boards though. thanks in advance
#18 11 years ago
OK. But I'm not proud of this amateurish work. It was something I did when I was just getting started. It worked fine so I never bothered to redo it with a more elegant approach.
Here are the CC lights: http://www.xoxide.com/cathode.html
Here is a shot from underneath.
#19 11 years ago
duplicate post
#20 11 years ago
And here is the unsavory part. I ran the wires up into the head and alligator clipped them onto the 18v test point and the ground braid.
......told you it was lame.
#21 11 years ago
if it works it works....you can make it permanent any time. Gotta decide if you like it first right? I like the idea....the uv light is 12v right? won't the 18v burn it up?
#22 11 years ago
Yes, 12v. But IIRC, the 18v test point was actually only about 14-16v. I have been running it for a couple years with no problems. Again, I would look at LED strip options before going with the cold cathode bulbs if I were doing it again.
#25 11 years ago
It's worth trying. I would make sure you try an UV strip. The decal colors are UV reactive which makes them really pop with the uv light. For that matter, you could probably place 2 different strips above the decal. Sounds like a fun experiment.
Good luck!
#26 11 years ago
I got a 9 led strip and did the same thing..I'll post pictures later
#27 11 years ago
Here are pictures of the 9 LED strip that I crudely installed in my CFTBL. I think it looks pretty good and adds a lot of light to the dark back of the playfield.
Creature_UV1.pngCreature_UV1.png creature_UV2.pngcreature_UV2.png Creature_UV3.pngCreature_UV3.png
$ 250.00
Professor Pinball
€ 99.00
Lighting - Under Cabinet
Watssapen shop
10,500 (Firm)
East Rutherford, NJ
$ 549.00
Juz PINBALL Mods
$ 150.00
7,800
Anaheim, CA
$ 280.00
Avid Creations Wireforms
$ 49.99
€ 24.50
Pin-Decals
$ 9.95
$ 27.95
$ 259.99
$ 49.99
€ 25.00
PPmods
$ 69.99
$ 45.95
Mitchell Lighting
8,000
Portland, ME
7,500
Matthews, NC
$ 5.00
$ 1,059.00
Great pinball charity
Pinball Edu
This page was printed from https://pinside.com/pinball/forum/topic/instructions-needed-for-creature-transparent-backboard-mod and we tried optimising it for printing. Some page elements may have been deliberately hidden.
