(Topic ID: 143551)
Installing Remote Battery Holder
By Blake
  • 21 posts
  • 11 Pinsiders participating
  • Latest reply 4 years ago by Brtlkat
#1 4 years ago
im installing a remote battery holder on my world cup and wanted to know how to identify the positive and negative with the original holder already clipped? there does not seem to be any indication on the board itself?
thanks
blake
#2 4 years ago
Williams World Cup, the System 3?
If so, here's a pic of a System 4 MPU, which is similar. The negative side goes to the connection that touches the large ground plane on the perimeter of the board.
http://www.pinwiki.com/wiki/index.php?title=File:WMS_sys4_MPU_board.JPG
Chris Hibler - CARGPB #31
http://www.Team-EM.com
#3 4 years ago
Quoted from ChrisHibler:
thanks just what i was looking for. and we are sure positive goes to the trace connected to the diode?
blake
#4 4 years ago
Quoted from Blake:
Well...I am.
And I've done hundreds of them.
#5 4 years ago
Well...I am.
thx a bunch chris!
#6 4 years ago
And if in doubt, use a meter with power on before you solder on the wires.. You will see +5 (or something close) if you chose the right pins.
#7 4 years ago
use a 4 battery holder and solder the diode in the battery holder
#8 4 years ago
Quoted from Raff:
...with the banded side of the diode pointing toward the positive connection.
#9 4 years ago
i installed it exactly like the first picture in the link showed. mine is a 3 battery holder. whats the benefit of the four with diode installed?
thanks
blake
#10 4 years ago
Quoted from Blake:
No benefit other than you can see that there is a blocking diode installed. The diode stops the batteries from being charged when the machine is ON. So on a three battery pack you will just have a diode in line with the positive wire. The banded side nearest the board the unbanded side nearest to the pack.
#11 4 years ago
Quoted from Blake:
thanks
blake
Your board is trying to charge whatever batteries it finds but typically you will not be using rechargeable batteries and you can damage regular batteries if you let it try to charge so the solution is to add that diode, it stops the charge.
#12 4 years ago
Quoted from Raff:
Why are there 3 wires soldered to the board in this picture?
#13 4 years ago
My guess, the 3rd is a ground wire to bulletproof old Gottliebs. It goes back to the frame of the power supply.
#14 4 years ago
Has anyone replaced the three batteries in an Addams Family. If so can you post a picture so I can see how to do this. Thanks.
#15 4 years ago
Quoted from DiggerPSU:
Your TAF is a WPC-089...
See this... http://www.pinwiki.com/wiki/index.php?title=Williams_WPC#Relocating_the_battery_from_the_MPU_board
#16 4 years ago
Quoted from RoyF:
As noted, that's a ground mod wire.
#17 4 years ago
yep that is a ground wire i added
6 months later
#18 4 years ago
I'm looking to add a remote battery holder to my Whirlwind. Can anyone provide some tips and pictures to help? This is my first time doing this.
#19 4 years ago
My two cents, if you intend to install a battery remote instead of an NVRAM:
1. Run the wiring for the remote all the way from the MPU to the coinbox, and leave the remote in or on your coinbox. That way, when you need to check or change your batteries, you'll only need to open the coindoor instead of moving the machine, removing backglass, possibly damaging backglass, etc.
2. Install molex connectors on the remote wiring 6-8" off the MPU. That way, if you ever need to remove the MPU or send it out for servicing, the remote is easily disconnected.
#20 4 years ago
How much harder is it to install NVRAM?
#21 4 years ago
Quoted from Pmaino:
Not to bad if you can solder . FWIW nvram will not hold your time and date.
$ 14.00
$ 11.00
$ 12.00
Siegecraft Electronics
$ 29.95
Pinball Photos
$ 159.00
$ 50.00
Just 3D Mods
$ 40.00
Arcade Arts
$ 999.00
$ 24.99
Lee's Parts
$ 19.99
$ 219.99
