My Stern Meteor has an upper flipper. It has a 4500 turn coil. Stern found this coil was breaking drop targets so they added a 1 ohm resistor to cut the power. I'd like to eliminate the resistor and install a weaker coil because the existing setup seems to pull a lot of current.
I seem to recall I can use a 5050 turn coil. Does that sound about right?
Bob
