I am in the process of swapping out all of the cr@ppy 2-prong power cords in a bunch of EMs, and as well putting in switches in the ones that have the hokey mains voltage going through the flipper and require opening up the baryswitch in the center to turn off!
For the stock-switched games (i.e., stock 2-prong cord), I've been tying in the hot line to the existing cord line that goes immediately to the fuse before going to the switch, and tying the neutral to chasses of the transformer & switch and to the coin door.
I suppose that I could also tie into the 4 brackets that surround the coin door (for Bally & Williams) and the side rails & legs, but I've read that that could be counterproductive. (So far, I've looked at Williams OXO, and it seems to have this grounding already in, with me just having to tie in the ground to a eye-terminal in the back.) Bally Wizard! has the 3-prongs already, but also the mains power going to the switch, so I plan to throw that out and just short the Hold relay so that it actuates upon power switch on, like the other switched EMs I have.
For the non-stock-switched games, I've been doing the same, but adding in the switch between the fuse going to the hot mains, which seems to mimic what 3-prong, grounded EMs did.
Am I doing this right, or should I be doing this differently? Thanks
