(Topic ID: 100826)
Installed a remote battery pack in a Roller Disco, and mixed up the + and - :(
By Jive
9 years ago
  • 5 posts
  • 4 Pinsiders participating
  • Latest reply 9 years ago by Jive
#1 9 years ago
So I had just fixed the issue of only being able to start a one player game, and remembered I had never installed a remote battery in it. I only had yellow wire with which to make the pack with, so even though I checked to see which was the positive and which was negative, somewhere along the way, I got them mixed up. (I should've marked them, but..) Turned on the power, and the machine went a bit crazy, so I shut it off. I then realized what I had done, and checked the mpu. Saw a resistor right by where the original pack had been that was fried, but everything else seemed ok. It was a 1/4 watt 62ohm, but all I had was a 1/2 watt 68ohm. I figured that was close enough, but now when I power it on, it seems to boot, and the displays light up as normal. I can insert credits, and hear sound. However none of the PF switches or coils are working. When I press start, it acts like the game has started, but the ball does not eject. Where do I need to start looking?
#2 9 years ago
Fuses? Sounds like you have additional damage that was either halted by fuses or other issues on the board.
#3 9 years ago
Quoted from bingopodcast:
+1
Also...did you have prior battery corrosion damage prior to installed the remote battery?
#4 9 years ago
Solenoid fuse is probably blown from when the game locked up.
Pretty common when the software locks up that solenoids pull in and blow the fuse.
#5 9 years ago
Turned out there was a fuse I missed, which I assume controlled power to the playfield solenoids. Replaced that and all is well!
$ 1.00
Pinball Alley
$ 89.00
That Old Pinball
Great pinball charity
Pinball Edu
This page was printed from https://pinside.com/pinball/forum/topic/installed-a-remote-battery-pack-in-a-roller-disco-and-mixed-up-the-and- and we tried optimising it for printing. Some page elements may have been deliberately hidden.
