The lights in the right side of the insert of the Radical I'm working on never switches on (the green circuit). I've replaced the burnt GI connector but that sadly didn't fix things.
Fuses are all ok. I've checked continuity from the transformer up and I get to the insert relay and then the circuit is open beyond that. Is the insert relay likely at fault? What should I be looking for?
