Quoted from spandol:
The fuses on the board check out. Wiggling one of the connections to the removed plug in the photo, made the right sligshot GI come back on. I just repined that wire. Could the pin off the board be corroded?
The game was on while changing bulbs. I did that to see which bulbs either needed messing with or a new bulb. In the process, all the lights went out, so it was all at one time.
When you say bridge rectifiers, is that the connections behind the board?
Ok, first of all yes, that pin off the board is probably shot - you may be able to wire brush it back to life, but 2 weeks from now the lights will go out again. That plating on those header pins decays over time, especially when the wires have been stressed and overheated. That header (the collection of pins as a whole) should be replaced. Actually, ALL of the headers and connectors on these old Ballys should be replaced for reliability, there are several threads about bulletproofing these elsewhere on Pinside.
The bridge rectifiers are in the middle of the board - see that black thing sticking out? Someone replaced that one already, there are 2 more on the back of the board next to it (BR2 and BR3) - one of those is probably toasted. Test with the game OFF.
