(Topic ID: 222529)
Inkochnito Bridge board - Pinbot
By Gomer1969
1 year ago
  • 4 posts
  • 3 Pinsiders participating
  • Latest reply 11 months ago by RichWolfson
#1 1 year ago
Looking for some help in wiring up the Inkochnito Bridge Board for my Pinbot.
My question is do I need a ground where the two orange wires hook into the 34v?
I have used the only ground wires on the 18V per the instructions.
Appreciate any help.
#2 1 year ago
All ground connections are connected to each other.
All grounds are the same.
You can even (for safety reasons) add an additional ground wire to the back metal plane if you like.
It never hurts to have an extra ground connection.
Not all connections on the Bridge Board need to be used.
I made some extra ground connections as there were spare connecting points.
Wires look to be connected correctly.
Did you check with my pdf file?
http://home.kpn.nl/p.koch3/Inkochnito_Bridge_Board.pdf
Peter
#3 1 year ago
Thank you Peter. Just wanted to triple check before I threw the switch. Everything works great!!
6 months later
#4 11 months ago
I did this install in my Pin•Bot today. Thanks to Peter for the great board and easy instructions. I was confused at first in that I didn’t understand that the board is mounted with screws through the rectifiers and actually floats off the backbox with no standoffs. The screws that held the old rectifiers were, of course, perfect for the job.
This is a MUST upgrade for any Pin•Bot as we try to keep them perfect for the next 30 years.
///Rich
$ 14.50
PinballElectronics.com
Gweem's Mods
$ 99.00
Pinball Sales
$ 17.00
$ 18.99
$ 9.00
$ 36.99
5,800 (OBO)
Waxahachie, TX
