This comes up rarely, but it just happened again, under similar conditions. I was in the middle of a game, with a pretty good score and closing in on an even better one. In the midst of play, suddenly the game starts warbling back and forth (I liken it to one of those European ambulance sounds, or at least the stock representation of them you hear in movies), with flashing lights, score displays go blank, and that's the end of that game. It probably resets spontaneously after several seconds of this most times, though I may have had to power cycle the game On & Off manually, in a couple cases. I cannot really I.D. any specific "trigger." In this latest example, I think it happened right after a shot went into the kickout saucer.
Have you run into this before -- on this or any comparable pins ? Do you know what the cause might be ?
This pin has Alltek MPU and lamp driver boards, rather than the originals, if that makes any difference. I would be more annoyed or concerned if this was other than a pretty rare occurrence.
