Did a quick LED test. This machine used to have colored LEDs for the inserts.
I’ve always thought ... yeah I’ll just leave them. Colored LEDs for inserts are fine right?
NOPE! I’m going with sunlights from Cometpinball.
That green just kills the red gradient, yellow and even the black colors of the insert. The last pic is the comet sunlight. It’s a frosted 2SMD. I’m going to try clear and no lens regardless... it looks spectacular! The ADVENTURE inserts need to use the flex bulb... so those will need to be a 1 SMD
For the record I don’t necessarily think that colored LEDs are always bad for inserts... you just need to be aware of the colors of the artwork and LED color choice when making a decision to use LEDs. For example a green LED would do fine on the green inserts of the wings on this playfield... as they are pure green. But for me I won’t mix ... I will keep them all alike.
I’m running these a little under voltage but both LEDs are placed at same distance to the insert. Also since it is at a reduced voltage the 1SMD may actually be better once I’m running at the correct voltage...either way green ain’t it!
3552123E-7FC3-454E-A8C8-390C66D6B3C0 (resized).jpeg0EB1EDB7-A5B9-462B-8123-C6FAA924B7D6 (resized).jpeg0E42EE4C-5E19-46FE-BC39-D72FC8A6E16C (resized).jpeg
