(Topic ID: 111745)
Indy 500 ground short message.
By Lotr-Hobbit
9 years ago
#1 9 years ago
Hi folks. Can anyone help me with this? I get a ground short message row 6,7,8 on my Indy 500. I have visually examined the Slam Tilt and coin door switches, all of the leaf type switches, and switch cable insulation and have not found any obvious shorts. Any ideas? Thanks.
#2 9 years ago
Is the error persistent or intermittent?
If the error is always there, you can try removing the switch matrix cables from the CPU board and starting the machine up. If the error still comes up, the problem is with the CPU board. If it no longer comes up, you need to keep looking.
#3 9 years ago
Thanks. I did remove the switch matrix cables, and the error persists. Now what? I truly appreciate your input.
#4 9 years ago
Oops. I was wrong. I removed the wrong matrix switch cable. When I removed the correct one (j209), the problem went away. All of the switches are now open.
#5 9 years ago
Game off, row and column connectors removed, check for continuity from those three row wires to ground.
#6 9 years ago
Quoted from terryb:
Yes this is the next step. And if this doesn't show the pins grounded then try disconnecting your opto power board.
#7 9 years ago
Man, I always forget the opto boards.
#8 9 years ago
Thanks. There was no ground fault with the rows with the row and column connectors removed. I will try the optometry board next. Thanks!
#9 9 years ago
Sorry, my autocorrect turned opto into optometry. I guess I should get better glasses and read my replies before posting...
#10 9 years ago
Fixed. Thanks for your help. It was the chip at u19 on the CPU board. Thanks again!
Nezzy's Pinball Prints
$ 9.99
$ 54.96
$ 219.00
Lit Frames
$ 18.95
$ 12.00
arcade-cabinets.com
€ 17.50
$ 17.50
Hardware
$ 95.00
Pinball Mod Co.
Charlotte, NC
$ 329.99
Arcade Upkeep
Filament Printing
This page was printed from https://pinside.com/pinball/forum/topic/indy-500-ground-short-message and we tried optimising it for printing. Some page elements may have been deliberately hidden.
