Hi everyone,
I have a strange problem on my indi500, It's impossibe to lock balls for multiball because the pin does not recognise when a ball is locked in the turbo...
But, in the turbo test mode, both optos that are mounted on turbo are good and detected.
At begining, I thought it could be a problem from the ball throught assembly, but each of the 5 optos are good, each balls is detected.
I change the opto board, just to see, but nothing happened...
I checked the optos voltage and there is 13v when working...
So I am running out of ideas in this case... if you have any suggestions.... Thank you.
