Can anyone tell me the correct part number for nyliner bearing at A-16317 assy?
I can see 20-8790,but there are many different sizes like -2 or -5 and etc.
This is not shown at the manual.
Hey Ara...
20-8790 is the Williams part number for a nyliner bearing used for 1/4 inch diameter shafts. (Bearing length .078 inch) That is what you need for A-16317.
Additionally, Williams used a suffix -1 through -9 for nyliner bearings with different lengths or for different shaft diameters. For example, 20-8790-1 is a nyliner bearing for a 3/16 inch shaft. 20-8790-2 is for a 5/16 inch shaft.
Wally
Quoted from Ballypinball:no 20-8790 is the correct number no -2
if it says 2 its 2x qty
Incorrect. They are the same part but any suffix number refers to a non standard size/diameter for that part.
Hm I was thinking the same -2 or -3 or-5 and etc are the specific size/diameter for that part.
But may be if there no number after the main part number,then by default it's 1/4 inch diameter.
You got it.
Standard is 1/4 inch with no minus suffix number.
https://www.pinball.center/en/shop/pinball-parts/flipper-components/miscellaneous/7169/nyliner-1/4-20-8790
-2 on the end would be same part but a 5/16 inch.
https://www.pinball.center/en/shop/pinball-parts/flipper-components/miscellaneous/7170/nyliner-5/16-20-8790-2
Quoted from pinsanity:You got it.
piss off pinsanity I know more about Williams part numbers than a hair on your head
I gave the correct info, I was saying if it had a 2 in the column qty is 2 not -2
go back to the funeral business
There is no quantity column on the A-16317 ball trough assembly page in the manual so the information given is erroneous.
After 27 years of buying/importing and selling pinball machines in conjunction with my current employment in the State AG's Department which provides just the right lifestyle/remuneration balance between the two, at this stage I am quite content in my career.
At the very least it certainly provides the outside perspective that seems to be severely lacking in some sections of the Australian pinball community.
This page was printed from https://pinside.com/pinball/forum/topic/indiana-jones-wms-nyliner-bearing and we tried optimising it for printing. Some page elements may have been deliberately hidden.
