(Topic ID: 297032)
Indiana Jones - Williams- Can't remove DMD to install DMD No Glare Film
By Jedi_Gill
  • 11 posts
  • 7 Pinsiders participating
  • Latest reply 2 years ago by Jedi_Gill
#1 3 years ago
Hello, I have a simple question.. I'm trying to remove my Indiana Jones Pinball Adventure DMD to install the No Glare Film from the inside.
I opened the top Panel and at the point shown below where all I need to do is remove the 4 screws I circled in Red.
However when I remove these 4 bolts and try to pull it up, it seems like it's stuck or glued somehow.. I'm pulling and I see the green circuit board bending resisting coming up.
I even watched this youtube video of someone else doing it on the same machine and he didn't have any issue.
<-- Starts at 4:00
Am I missing something, is there an adhesive I'm not aware of. If anyone can help it would be most appreciated.
Thanks.
#2 3 years ago
There may be some foam stuck between the display and the speaker panel. The WMS factory serial number sticker says it's original. May have never been removed.
Start at one corner and use a knife to get under the display. Slowly work from the corner and it will come out without breaking anything.
#3 3 years ago
Quoted from phishrace:
It is indeed original and has never been removed. I will follow your advice and report back.. Thanks again.
#4 3 years ago
Do yourself a favor and get those batteries away from the boards. If you don't go with NVRAM, get a battery extender so you can place the batteries far from the board in case of leaks.
#5 3 years ago
Quoted from Jedi_Gill:
I even watched this youtube video of someone else doing it on the same machine and he didn't have any issue. <-- Starts at 4:00
Thanks.
I had the same thing it was stuck on the foam too the dmd from 1993 so all I did was pull abit from one corner too the other bit by bit and my let go after a while hope this helps
#6 3 years ago
Quoted from Williampinball:
Thanks, I'll give this a shot. Much appreciated.
#7 3 years ago
Just rip it off like a band-aid.
#8 3 years ago
I just pulled a CFTBL apart and it was stuck due to the foam between the board and dmd... even if you just carefully cut the foam.
a different question - what are those bolts and where can I get new ones that old the dmd?
#9 3 years ago
Quoted from swinks:
Bally/Williams PN 4506-01106-24B
https://shop.mrpinball.com.au/product/6-32-x-1-12-flat-head-speaker-screw-steel-black-oxide/
1 month later
#11 2 years ago
Update, Indeed the glass was stuck to the foam. I just carefully pulled each section apart and once the 4 straight sides gave way it came apart. It's probably never been opened ever. I installed a LCD color DMD and am in heaven. Thanks guys for the confidence to pull it apart even though it seemed stuck at first. Hoping this post helps someone else.
$ 41.99
Lee's Parts
Various Novelties
Pinball Photos LLC
€ 160.00
Pino Pinball Mods Shop
$ 75.00
PFX PinMods
$ 1,059.00
$ 59.95
pinballmod
$ 449.00
€ 50.00
2step’s shop
Pinball Photos LLC
$ 1,419.00
Pinball Photos LLC
$ 449.00
10,000 (Firm)
West Hartford, CT
10,950 (OBO)
New York, NY
$ 69.99
$ 123.00
Lenticular Designs
$ 69.99
$ 12.95
Great pinball charity
Pinball Edu
