Hi,
I recently got an IJ and have some technical problems at the moment. As I have no experience with this kind of problems a little advice is highly appriciated.
- Path of adventure worked for some days but is not functioning anymore:
Error that is coming from startup and test menu: check switch 94 and 95. POA is not moving at all when testing.
- Left slingshot does not work:
Checked below playfield and when moving the crank the slingshot is working. Probably not a mechanical fault?
- Right slingshot works but 'slings' very weak:
