Hello gents,
I just restored my Williams Indiana Jones. Was working 100% after fixing multiple issues (including the idol and trough). Then I put her on a table cart ... Wheeled her into place ... Was all excited to play ... And the darn Path of adventure is not working.
- POA worked seamless before I moved machine.
- red light is lit on the bridge board under playfield.
- get error message for POA in diagnostics.
- motor also doesn't move in diagnostics
- already changed fuses 115 and 116
- cleaned flipper optos with isopropyl.
- in switch test optos on mini board behind POA work.
- odd discovery, on the CPU board the switch molex connectors were plugged into different J numbers than the manual lists. However the game functioned normally plugged in like this before I moved it across my garage.
I am guessing that since the red light is on for the bridge board under playfield that power is getting there. Does this leave the motor as the only culprit? Should I try to reflow solder to the motor? Could there be anything else interfering here?
How do I best check the chain with my multimeter to deduce further? Specific instructions on what to set my meter to and where to test would be helpful.
Thanks,
Hoser
