They're looking really good KornFreak28 !! Can't wait to get mine!!
Quoted from MacJedi:They're looking really good KornFreak28 !! Can't wait to get mine!!
Thanks! I’m this close to wrapping up yours and 5 others
Quoted from KornFreak28:Another one
I call that one! that’s the design pattern I like.wow.
Quoted from Scandell:I call that one! that’s the design pattern I like.wow.
Might actually be mine….can’t wait! Impressive work and detail.
Quoted from Devo10:Might actually be mine….can’t wait! Impressive work and detail.
Looks like it is! I’m going to try and ship 6 orders all at once because the lines at the post office are INSANE!
The packing will have to be even beefier now (if you can believe that) since now the motor controller mod mother board will be in the box along with the instructions on how to set it up. You will also receive a different set of instructions via email (since I can’t seem to figure out a way to do a bar code thing) on how to safely remove the planes from the box and a whole lot of other information that you must follow.
Also, for anybody that has my planes (original wiring) please note that the planes MUST spin during the following events:
Plunge (medium spin)
Single drop target (short spin)
Right ramp when lit (short spin)
Lock a ball (long spin)
Multiball (really long spin)
The ruins flasher on top of the ruins goes off when you hit these targets.
There’s been a lot of customers that for whatever reason had the plane/super ball and ruins flashers reversed or mixed with the right ramp flasher since the connectors are very similar. The player doesn’t know and the planes don’t spin as much and the correct flashers don’t go off when they should. If your planes don’t spin during these events contact me and I will help you. Easy fix.
Also, I will set the controllers to what I think it’s the best speed/time combination. You may play with these controls at will. You may want to take a picture of them so you know exactly where I set them at in case you want to go back to my settings.
Good to know!
Quoted from Onwallst:This is the best mod for any IJ. I love mine! It finishes the game. Great work!
Good to hear from you brother! Enjoy!
So if we have the original plane could we buy a board and hook it up underneath the playfield and get the same effects?
Quoted from shepP:So if we have the original plane could we buy a board and hook it up underneath the playfield and get the same effects?
Not that easy. We are working on it but no guarantees. I’ll keep you posted
Please also for me.
I want all two planes with painted figures and all you suggest as the best.
I want also plastic about airball.
I would want also customised mini playfield , lite jackpot and ruin i seen in your post on a member’s pinball. Have you suggestion?
Quoted from Ghiandalf:Please also for me.
You mean these?
9F6C8C3C-920D-4D61-9024-C82D43DA43C7 (resized).jpegthose plastics are cool! and the planes too. where can I get more info about the planes and everything else?
Quoted from Pin_Fandango:those plastics are cool! and the planes too. where can I get more info about the planes and everything else?
The plastics were done by Medisinyl and info about the planes right here
Quoted from oopsallberrys:Can I be added to the list for both planes with all the options? Thanks!
Sure I’ll add u to Batch 6! Thanks!
Do you have sticky posts or links to the pages with the information?
If not, I would recommend creating them.
I tried to get through some pages but it is 50 pages and skipping and skimming through leads to miss information.
Would like to know price, turn around time, and pretty much everything else.
Quoted from Pin_Fandango:Do you have sticky posts or links to the pages with the information?
Sorry I don’t and I really don’t plan on creating them. The planes have evolved and changed so much since the first Batch, so creating sticky posts is not in the menu for me. If you want info just PM me. Thanks!
Quoted from KornFreak28:Sorry I don’t and I really don’t plan on creating them. The planes have evolved and changed so much since the first Batch, so creating sticky posts is not in the menu for me. If you want info just PM me. Thanks!
I will pm you thanks
Due to an increased interest in the Plane rescue service I will be posting a “Menu Style” link/post with all the relevant information such as prices and options since I have been getting a lot of PM’s as of late asking for info.
Sorry, there’s no sticky notes or links in this thread. This is a hobby that got bigger and bigger and I just don’t have the time to sit down and work on links or pages as I rather spend that time building planes. I will work on this menu, post it and make it a sticky post for those of you interested.
As always, Thank you for you interest! The controller mod ROCKS!!!!!
Quoted from KornFreak28:Due to an increased interest in the Plane rescue service I will be posting a “Menu Style” link/post with all the relevant information such as prices and options since I have been getting a lot of PM’s as of late asking for info.
Thank you for taking the time to do this. I'm sure it will actually save time in the long run, as newcomers can be pointed to the forthcoming post.
Quoted from gorditas:Thank you for taking the time to do this. I'm sure it will actually save time in the long run, as newcomers can be pointed to the forthcoming post.
I hope so
The first 6 orders are being calibrated right now. The planes have different propellers with different blades and weight. I’m calibrating so both planes stop spinning at the same time. Since prop weight and blade length play a role, I’m marking where you should connect the Fighter (F) and the Tiger (T) to.
This setting is what I feel will get you the most satisfaction and make it a more enjoyable experience. If later on you decide to crank up the speed and time all the way, that will be up to you. My settings will reward you with a spin for each corresponding shot you make.
The good thing is that Speed and time controls are fully customizable to your liking. Play around with them and see what you like!
EDC83963-5196-4F22-A678-62967FAFDCDC (resized).jpegQuoted from CashMoney:Man I can’t wait! The amount of work that goes into these planes is truly amazing.
Honestly, There’s a lot of work that goes into these planes. Lots of Time consuming details, that’s for sure but I really enjoy incorporating them to the planes!
For future batches, I will do a little vote on some of these details and add-ons to see where they stand and how important they are to some of you.
Quoted from KornFreak28:Each controller mod is individually marked and customized
What a stupid user name and what is a “Hanced Airplane”? I mean Harrison Ford was in both movies but having Solo in the plane is just silly. Unless Chewie is with him… or Lando.
Quoted from jedimastermatt:What a stupid user name and what is a “Hanced Airplane”? I mean Harrison Ford was in both movies but having Solo in the plane is just silly. Unless Chewie is with him… or Lando.
At first I thought, "dude, why be such a jerk." Then I checked for sarcasm. Always check for sarcasm... Sadly, I've seen people that aren't kidding. Happy for you to see your's ready to go out!
I still don’t get it....The word is Enhanced btw
Quoted from KornFreak28:I still don’t get it....The word is Enhanced btw
See the photo in post 2482, especially the user listed and exactly what text is visible on the photo.
Quoted from gorditas:See the photo in post 2482, especially the user listed and exactly what text is visible on the photo.
Quoted from Pin_Fandango:let us know when the sticky is ready so I can check it and save you from another private message
Will do
Quoted from stlmo:Has anyone added any lights on the playfield to show off the planes? My pinball room is pretty dark by design. Any suggestions…
Check your J120 and J121 connectors. I think your GI is toast
Quoted from Mikespinball:I don't have any lights on my planes, but did just add an LED to the inside of the German plane cockpit so you could see the pilot.
[quoted image][quoted image]
I think Dr Jones Senior should have an LED at the end of the machine gun when the planes fire... JUNIOR WE HAVE A PROBLEM!
Wow an early fighter plane! Thank you for the pics and awesome led idea! Great job!
my .02 on the sticky/form.
Just come up with a simplified list of options. People interested can just copy/paste it with their choices left behind (and other options removed)
Another thought would be a google "sheet" with a form anyone can use to add their name to the list (with the options selected). submissions would be added to the sheet that only you can manager from there.
If you need any help with this, I'm sure people would help (including myself)
Cheers!
Quoted from arcadenerd925:my .02 on the sticky/form.
Cheers!
Thanks! We are working on the list and it will be posted soon
This page was printed from https://pinside.com/pinball/forum/topic/indiana-jones-plane-rescue-service/page/50 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
