The following is are the installation instructions:
As I said from the very beginning, you will have to do some work to install these planes.
The easiest plane to install is the fighter plane. Why? because you can fish the wires rather easily to the underside of the playfield. You must secure the plane to your mounting bracket by using the holes I drilled for you. You can also drill new holes for better positioning but BE CAREFUL!!!! There are wires inside the plane! If you want to drill new holes, ask me first and I can guide you. You must remove your right ramp wire form. Then remove or lift your right ramp just enough for you to run the wires into the underside of the playfield. You can secure the fighter wires (shrink wrapped section) to the right ramp by using wire ties. See picture
The biplane: The hard part about this plane is running the wires into the underside of the playfield. The wires go under the left ramp. You must do whatever it takes to fish the wires into the underside. You can remove or lift the left ramp, you can remove or lift the jackpot plastic in order to run the wires in a neatly fashion. You can wrap/hide the wires around the pop bumper cap for a more professional looking installation. Install your biplane and run the wires into the underside of the playfield and that is all there is to it. This plane is probably the hardest one to install.
Once that's done, you are almost home! Now it's time to hook your planes into the connector!
Some planes will have Red and White wires. Some will have Red and Black wires and some Will have Black and white wires. If you get a Red wire, that means RED (duhhh). If you get a Black with white, Black is RED. Is you get Red with Black, Red is Red!
The wires are solid and are meant to be inserted into the connector pins. Red with Red and the other wire (white or black) goes to the other wire in the connector, color may vary. You must find the sweet spot and insert the wire so it's snug. You can can install both planes into the same connector (so they spin at the same time) or into different connectors.
I recommend you use the Ruins connector, or the dogfight (plane leds) connector only. These seem to get the most action during the game. You can install the planes into any other flasher connector of your choosing.
Once the wires are inserted, you can secure them with wire ties or electrical tape so they don't move on ya.
You must ONLY connect the planes into a FLASHER power source. Under no circumstances can you hook them to the GI or Lamp matrix! You have been warned!!!
You can insert the wires or solder them into a flasher socket. It's all up to you.
You must make sure you get a good connection when inserting the wires into the connector. The planes will not work if you get a so so or bad connection. That's it! Let me know if you have any questions.....Enjoy!
*****Pics coming******
