I'm having trouble diagnosing a problem with the top post on my Indiana Jones: The Pinball Adventure. This is the post that sits at the end of the bridge, right before the Path of Adventure. It is my understanding that during multiball, the post should come down and allow jackpot shots to fully travel around past the PoA down that left side and feed to the left flipper. Based on playing the game in Zen pinball, that is an accurate assumption. This is not happening on my game.
* The top post behaves normally when the ball is shot up there while PoA is active. It holds the ball for a second and releases it into the PoA.
* The coil power test appears to perform nominally. It repeatedly pulls the post down.
* The coil hold test for the top post appears to do nothing. I have no real experience working on games, so it's not clear to me whether or not something should happen during this test. I thought maybe the hold power is not enough to pull the post down, so I tried manually pushing the post down to see if it would hold, and it did not. I'm still not sure what to expect for that test however. I get the same behavior on the diverter power hold test, and my diverter is working as expected, so I suspect "nothing happens" during the hold test is maybe normal?
* When jackpot is lit on the right ramp, and I shoot the right ramp, the post is always up. After the ball bounces off the post, the post does this kind of freakout where it pulls up and down several times before the ball rolls back from ricocheting off the post and releases into the PoA.
* I thought maybe there are some switches leading up to the post that might trigger it to come down during multiball when the jackpot shot is hit. There appear to only be two switches in that path. There is the opto at the base of the right ramp and the switch that sits right before the top post. Both of those switches test fine however.
Based on the descriptions above, I have the following questions:
1. Is it normal for the coil hold test to appear as if nothing is happening, or is this an indication of a problem?
2. Can someone verify the proper behavior of the top post during multiball? Should it come down and stay down for the duration of multiball? Should it only pull down and stay down based on some series of switch activations?
Thanks for reading.
