New! Dark mode!
(Topic ID: 34848)
Indiana Jones Mode start light not working ?
By alimerick
7 years ago
  • 7 posts
  • 3 Pinsiders participating
  • Latest reply 7 years ago by alimerick
#1 7 years ago
Going through an IJ. Start Mode light does not work. This one has a socket with 3 tabs that was reused from something else. 1 tab is not used but has a very short clipped piece of yellow wire still on it. Should the start light socket have a diode on it? Looks to be wired correctly. Red-Brown row to J133-1 and Yellow-Brown to J137-1. All other lights in the row and columns work. Bulb is good.
Thank You
Happy New Year
Andy
#2 7 years ago
Yes there is a diode.
#3 7 years ago
Compare it's wiring to other feature lamps and see if wiring and silver band end of diode are in the right spots.
Base colors on wire will be the same, stripes will be different colors. But the base color and diode are the same on every socket.
#4 7 years ago
Here is a pic of the lamp in Question.Disregard the solid red and black wires.They are an add on to light the red saucer.
#5 7 years ago
Does it work with the red and black wire off ?
#6 7 years ago
Socket on this one has the diode with the band the same as picture. Red wires same as pic. Yellow wires are on the socket tab where the black wire is in the pic. Tab where red wire is in picture is not used.
Thank You for your help.
Andy
#7 7 years ago
Moved wires to match the picture and it works.
Thank You
Andy
$ 149.00
Sparky Pinball
$ 59.95
pinballmod
