Indiana Jones Mini-playfield Not Centering
By Madmanx
1 year ago
Stats
  • 9 posts
  • 3 Pinsiders participating
  • Latest reply 1 year ago by Madmanx
Find
Search this topic for posts matching certain words or written by a specific Pinsider. Or both!
#1 1 year ago
I am bringing my IJ back to life after storage for ~10 years. I had acid damage on the CPU board and have just replaced with a new board. The game fires up and works "almost" perfectly. The mini-playfield goes through test and passes, but it kicks to the extreme right. I've manually tested it and it indicates it works (goes far right and thinks center is left). I can move it far left by repeatedly pushing the manual test to the left. Switches indicate they are reading. It just doesn't want to center.
I've taken the mini-playfield out, cleaned the optic board/sensors, but here's where I may have screwed up. While apart and having the do-dad arm (that goes between the optics to indicate right/left) off the shaft, I ran the test. When everything completed or stopped, the shaft on the motor did not stop with the flat side of the shaft pointing up. I (and please don't hate me) manually, with my hand, rotated the shaft to the correct orientation. I fear I have screwed something up but I would have thought there would be logic to figure out "center" when the do-dad was on and positioned between the optics.
Any and all suggestions are welcomed.
Thanks, Bud.
#2 1 year ago
when it is far right, what happens if you then recenter it? will it not then go to the right and goes too far to the left?
#3 1 year ago
Quoted from Lermods:
I've tried to leave it "centered" by going into the test mode and pushing the left direction until it is centered. Once I come out of test mode the playfield repositions itself far right. I shouldn't say this, but I've also forced it to center with my hands but it won't stay there either. When the game is powered on you can see the playfield shutter to the right, and very quickly kick left (to about center position), and then positions back far right. It's frustrating.
#4 1 year ago
hard to know without seeing it but are you sure the shaft is seated in the motor properly? I would loosen the set screw on the shaft, let the game do what it wants with the mini pf, then center the mini pf and tighten the set screw. if that doesn't correct it, there is something else going on. It's not a complicated mechanism, though it can be hard to get just right. Yours sounds like is far from just right.
#5 1 year ago
If you need to bump the motor a couple times to a different position just use a 9 V battery with some wires and touch it to the motor and you can rotate it into the correct position that way. Don't ever try to force it into position by hand.
#6 1 year ago
And You are correct, the flat portion of the shaft should be directly on top when the motor is in the neutral position.
#8 1 year ago
youtube.com/watch?v=4Eo7I6gQPEU&feature=youtu.be (type the www. just before this link to see it. I'm too new to the forum to be able to post links yet)
I've tried to take a video of the symptoms - see the link above. You can see that the playfield will go to the extreme right but only go to the neutral position for left. I'm now wondering if I have a problem with the opto board itself?
I've pulled the motor out of the gear housing (not sure if I'm supposed to do that or not - but frustration is starting to kick in) and centered the pf. I put the motor back in and it immediately kicks to the far right upon power on. I took the little do-dad arm off to see what the motor would do without the opto. It turns about a 1/4 of a turn and stops. Rinse and repeat (meaning when in the con't test mode it turns a 1/4 turn and stops. I put the do-dad arm back on when the flat side of the shaft was up and it was positioned between the left/right optos. Exit test mode and whammy, hard right. I'm about ready to start throwing parts at it.
Any other ideas?
Thanks.
#9 1 year ago
The mech is pretty simple. The motor shaft (gear) inserts into the larger gear housing from the back side. Out the front of the larger gear housing is the shaft that the do-dad arm (for the opto) and the playfield attaches to. The shaft has a flat side that should rest - in neutral position - facing up. The set screws for the do-dad and the playfield screw down to that. The collar for the do-dad and the playfield are made to fit on only one way. In other words if the set screw is loosened, the shaft will not rotate freely in the collar.
Based on my limited knowledge here, it seems that the opto isn't reading and sending the right signal to turn on the motor and turn it off in the neutral position. Almost seems it's not working correctly or the "logic" isn't functioning correctly.
Thanks. Bud
#10 1 year ago
All too often when someone finds the solution to their problem they never close/conclude their post. This makes it difficult for people that search for a post on the same subject, to understand what one solution might be. So with that in mind, I'm posting my solution to my problem. Turns out I had a bad moto opto board for the Path of Adventure. This is the board that the do-dad (interrupter) uses to indicate when the mini playfield hits the end of travel (right or left). I don't know which opto on the board was bad, but I assume it was the bottom one (indicating left). Part number A-16657 - $29 from Marco. Now onto finishing shopping the machine. Woo hoo.
Thank you to everyone that responded with suggestions. I truly appreciate the input.
Bud
$ 29.99
Buffalo, NY
Apparel - Unisex
ArcadeMade
$ 28.00
KAHR.US Circuits
$ 21.00
$ 40.00
$ 69.99
$ 40.99
Lee's Parts
$ 69.99
$ 99.99
€ 95.00
FlipperLED
$ 69.99
$ 49.99
$ 69.99
$ 129.00
LED OCD
$ 8.50
Bright Lights Pinball
5,900
Note: This is an old thread. The last post was made to it 454 days ago. Resurrecting old threads is not necessarily a bad thing, if you think the topic is still relevant and/or your post is beneficial to it (e.g. following up on something). In other cases, it might be better to create a new topic.
Wanna join the discussion? Sign up for a Pinside account, or log in if you already have an account.
