I am restoring this game, it was fine a week ago. I did install a "Super Ball" switch before the problem started. I don't know if the Slam Tilt started right after I installed the Super Ball switch, it's possible.
I read quite a few other Slam Tilt threads, most say they hit this or hit that and then got the error message. Mine happens on startup. I also get an Idol error and it doesn't turn at startup any more. I tested the cabinet floor tilt switch in the switch test, it did not work. The plumb bob tilt switch does work fine. The contacts are not touching at rest. I unplugged it, still get the Slam Tilt error.
In the switch test the other switches in the Slam Tilt row and column work fine.
Should I fix the Idol issue first?
Thanks for the help!
