Okay, but only because you asked for it. I am terrible at drawing.
The U-bracket is made from a small piece of coat hanger wire. To make this work, you will need a longer bolt but still one short enough not to stick out from under the bottom of the plane. The bolt goes in, then the bracket holding the plane in place, then a lock nut to hold that down. On top of that I put a washer, then the U-shaped wire, then another washer and lock nut. The motor then is cradled in the U. It stays in place pretty well with just the motor's own magnets, but I also added a plastic strap. That's all there is to it.
One inaccuracy in this drawing, now that I look at it, is that the U goes all the way to the front of the plane. There is no significant gap, unlike the above picture. Also, all of this is a lot more crammed than appears in the drawing. There is almost no space between the sides of the plane and the U-bracket.
