Quoted from TheRingMaster:Yeah those protectors will be nice! Fingers still crossed they will fit.
So are there protectors or are they in the works?
As far as I know they are still in the works. Havent heard anything more about them yet... I think ledge should know, hes the one in touch with cliffy while I handed over the measurements.
Lets hope they get done soon, would be nice to have!
Has anyone had an issue with the Alien Head not opening? My ID4 machine is having difficulty with this now. I can bash the alien 10 times on 1 ball and it won't register that it has been hit and then maybe here or there it gets lucky and finally registers the hit? Super annoying considering this is the only way the get the main multi-ball feature. Is there a fiber optic problem or switch problem? Any help with this would be appreciated.
Hi there vwallat99!
I would check the opto switch that is just in front of the alien head. Theres no physical switch for the alien head (for registering ball hits) but an optical switch. When the light beam is interrupted it registers as a hit on the head.
Try to enter switch test in the games menus and see if you can trigger the switch easily with your finger or by rolling a ball towards the head. If not, next step is to check the connectors on the opto boards that sticks up from under the playfield on each side of the head, in front of it. They have to be tight and not loose causing bad connections. If that fails i think maybe your opto boards have gotten worn out or misaligned. Check that they are aligned properly and did not come out of place. Maybe theres a loose screw or maybe cold/cracked solder joints on the opto boards.
Hope it helps somewhat!
Anyone got a score/instruction card for ID4 or other sega game? The right hand one that says something like 3 balls per play? I have the instruction card but not the other.
Not looking for some fancy new custom card (yet at least) but rather the original one used on location. A scan or even a decent picture of it would do.
Yes please
Yeah, a deeper rule set would've been nice. Now that Independence Day 2 is on its way maybe it's time to do an id4 2.0 like the bop 2.0. A few missions to accomplish etc before killing the mother ship would be cool!
wierdeer, hehe.. well that could do =) And yes the 2.0 ruleset would be pretty cool. i doubt stern or someone else will do an ID42 anytime soon.. depends on the success of the movie ofc but.. on the other hand a JJ version with LCD screen could really be awesome!
HarrieD, the world is smaller than we imagine.. so maybe.
Oh! Thats cool =)
So.. guess its time to start programming the ID4R game rom now.. as well as change the space ship to a more modern one hehe..
A couple of games from now JJ or Stern should make a game out of the new movie! Could actually be pretty cool especially with the LCD screen and all.
Here is mine after I put LEDs in my playfield has zero damage... Someone cut out the slam tilt so switch is always open... Vuk randomly pops from time to time need to track down that switch or diode... RAmps have small cracks that are not visible left ramp has bigger crack but someone did a pretty good job repairing it with jbweld ... Also my release the attackers and release the destroyers are red inserts where most are green and my lock inserts are yellow where most are green thought someone might have replaced them till I saw a video with the same configuration. Anyone know what's up with that
Above are pics I took of my tear down for reference thought they might be useful for some one else.... Love this game even tho the rule set is shallow the ramps are hard as rock to hit and that right loop shot with the flipper in the way is hard for the double or triple jackpot is challenging very challenging my best score so far is 2.9 bill this pin should have a way better rating than it does.
Quoted from wierdeer:Here is mine after I put LEDs in my playfield has zero damage... Someone cut out the slam tilt so switch is always open... Vuk randomly pops from time to time need to track down that switch or diode... RAmps have small cracks that are not visible left ramp has bigger crack but someone did a pretty good job repairing it with jbweld ... Also my release the attackers and release the destroyers are red inserts where most are green and my lock inserts are yellow where most are green thought someone might have replaced them till I saw a video with the same configuration. Anyone know what's up with that
No idea but that is interesting I don't think that I've seen a ID4 with those inserts. But your LED set up looks good and probably makes those inserts for the attackers and destroyers work. Is that blacklight on the bottom of the field??
Quoted from TheRingMaster:Hi there vwallat99!
My opto board was kind of hacked from whomever did work to it last. I finally had the ambition to get in there and take a look. My ID4 is looking and playing amazing once again. Thanks for the tip to check out the board.
Quoted from vwallat99:My opto board was kind of hacked from whomever did work to it last. I finally had the ambition to get in there and take a look. My ID4 is looking and playing amazing once again. Thanks for the tip to check out the board.
That's great to hear! Always nice to contribute =) I think my restoration is pretty much done now but I still need to fix the stickers for it and then take a few pictures of the game before I call it finished. Will do as soon as I have the time.
Quoted from TheRingMaster:That's great to hear! Always nice to contribute =) I think my restoration is pretty much done now but I still need to fix the stickers for it and then take a few pictures of the game before I call it finished. Will do as soon as I have the time.
.... then please change the thread title to ID4 Club.... everyone agree?
Quoted from vwallat99:I think so , this machine needs some love.
Show me some...
Not sure, maybe a bit later but the new movie might have at least a little interest going. Still would like to see a new machine based on the new movie with today's tech.
Anyone knows if it's possible to move the thread from the restorations sub forum to the all clubs one? And.. How to do it..
Quoted from TheRingMaster:Anyone knows if it's possible to move the thread from the restorations sub forum to the all clubs one? And.. How to do it..
Now you got me.... haven't thought about that.....
I'll check it out. Worst case I think robin or so could always move it. Or maybe I'll change it back and create a new separate club thread after all. Can always put links between them.
Ended up creating a separate club thread instead. Think it's better after all, let's keep the discussion going there! I've linked both threads together by posting links.
Here's the club thread:
https://pinside.com/pinball/forum/topic/independence-day-id4-club-owners-and-fans#post-2986230
This page was printed from https://pinside.com/pinball/forum/topic/independence-day-id4-restoration/page/6 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
