Quoted from wayout440:I would suggest to just check TP5 on the MPU board for stable +5VDC with low ripple (<500mVAC).
It's stable.
Quoted from wayout440:I did note this in the repair docs:
The Game only Starts up "sometimes".
If the MPU only starts up properely "sometimes", replace Q1 and Q2 (both 2N3904), Q5 (2N4403), VR1 (1N959B or 1N4738A) and CR5 (1N4148 or 1N914). These transistors and diodes need to be in perfect working order for the MPU to boot reliably.
The transistors and diodes all seem to test ok. The capacitors appear to supply steady voltage, and were already replaced by a prior owner. I'm not sure how to test the variable resistors.
